Tesla Battery Modules - Used with Warranty
Yaro
Hello I am located in Sacramento, CA and I have for sale a number of battery modules removed from Tesla Model S vehicles. All units are tested and sold with a 6 month warranty. Most of the cars I purchase are newer and usually have under 30k miles.I can ship these anywhere in the 48 US states. I can ship by freight aswell to Puerto Rico, Hawaii and Alaska.
Pricing(Shipping not included):
1-3 Modules: $1250 per unit
4+ Modules: $1175per unit
Module Specs:
Voltage range for 1 module is about:
18.6V soc 0%
23.1V soc 70%
24.9V soc 100%
Capacity 232Ah, 5.3kWh
Dimensions:
Length: 27"
Width: 12"
Height: 3"
Weight: 55 lbs
Warranty Information:
Each unit includes 6 month general warranty and does not apply if the battery is improperly installed, damaged from discharging or overcharging or if damaged from improper cooling/heating.
gregoinc
I would recommend you give a location, as this forum is used globally :)
HollandNL
Little side note for everyone handling Tesla batteries:
Please drain the coolant!!!
I see it leaking on the pictures...
best practise:
-blow out 90% of the coolant while the modules are in the pack
-blow out the rest from every module (use the coolant lines from the battery for this)
-cap the coolant tubes with an 8mm rubber cap
if the coolant leaks onto the batteries, it -will- cause cellsdischarging and imbalance in the battery. If you have this happen it is very difficult to clean out (use destilled water and than alcohol to get rid of it)
Yaro
best practise:
That's what we normally do, these specific picture we didn't individually blow them out just yet.
