- Oct 7, 2016
- 2,219
Quote:
For those of you who want to keep your battery system lean and mean, reduce the cabling, and get powered faster, the 24V HSKY is where you should begin!
In terms of kWh/ft3, the 24V HSKY is the most space and weight efficient 24V battery on the market today. Whether you’re looking to optimize your battery system for boondocking in your RV, or build your ideal off-grid home system, the 24V HSKY is your solution. Utilizing brand new cells paired with our advanced BMS, you can rest easy knowing that 24V HSKY will provide you with safe, energy efficient power that can be used safely within a wide temperature range. All you winter campers can finally get that extra day off grid that you’ve been waiting for!
Plus with a high maximum charge current, and guaranteed lifespan of 10+ years, you’ll be charging faster and lasting longer than the lead acid alternative. Why replace your batteries every 2-3 years when you can get over 4 kWh of capacity at the best price/kWh available today for 4x as long, with ZERO MAINTENANCE! Pick up your HSKY today and power your next adventure worry free.
Website: https://bigbattery.com/products/24v-hsky-elite-lfp-228ah-6kwh/?ref=47&campaign=ForumReviews
Configuration: 8S (Series)
Voltage: 24V
Ah Capacity: 228Ah
kWh Capacity: 6kWh
Wh Capacity: 6000Wh
Configuration: 16S1P
Voltage: 48V
Ah Capacity: 103Ah
kWh Capacity: 5.3kWh
Wh Capacity: 5300Wh
View: https://www.youtube.com/watch?v=xJWSlMk6ssI
View: https://www.youtube.com/watch?v=IhiO3gE9_pE
View: https://www.youtube.com/watch?v=ynbGyHvgMAg
24V HSKY ELIT $2,299 usd
Chemistry: LiFePO4 (New)Configuration: 8S (Series)
Voltage: 24V
Ah Capacity: 228Ah
kWh Capacity: 6kWh
Wh Capacity: 6000Wh
48V HSKY $2,199 usd
Chemistry: LiFePO4 (LFP)Configuration: 16S1P
Voltage: 48V
Ah Capacity: 103Ah
Wh Capacity: 5300Wh
