J_Mack58
- Apr 7, 2021
- 196
I’m adding on or possibly replacing a nice 14s80p battery made with 18650’s cells. I never tested not one cell. Matter of fact up into last week I never owned a tester. Now I own two. With my limited experience I learned there are four type of bad cells. 1. Shorted or Heaters, they get hot when you try to charge them. They don’t charge and could damage your charging source so you stop charging them and mark them as bad. 2. Open, the CID has popped from cell over pressure and I‘m not brave enough to reset it. (Seen it done on YouTube though) Risk not worth getting the cell to work again only to have the capacity suck because it was damaged in the process of being over pressured due to overcharge or too heavy discharge. 3. Self-Dischargers, they charge, they don‘t get hot but the charge drops like a Jamaican Bobsled team coming down the Swiss Apps. 4. Low Capacity, they charge, don’t get hot. Discharge a little worst than a good cell but using our great “Battery Tools” on this site the cell suppose to be a 2900 mAh and you get less than 1000 mAh. Usable but not worth it.
So with this batch of 280, 26650 cells I plan to test every one of them. Notice I wrote “plan to”. I’m not close to half way and I‘m already tired. The tiredness comes from waiting. These cells come from a 4s5p battery…20 cells.
Inserting $50,000 question here.
if I bulk charge the 20 cells, and they all charge to 3.6v, (CID good)I get no heat, (Non-Heater) I pulled them off the bulk charger one at a time and they hold a solid 3.59xx volts for a minute (Non-self discharger) and the next day still at 3.592x volts…. Capacity test a random 4 cells from the 20 with my Opus and they range 30xx mAh to 32xx mAh can I call the 20 good?
Somebody pleeeeeeaaaaase say “yes”.
