OffGridInTheCity
Moderator
- Dec 15, 2018
- 2,687
For me, its not about drawing power from battery (I agree with comments on this) butits about isolating the battery 100% from the system while I work on the system. This isa personal choice. When I put the shunt-trip to OFF, I like to *know* that 'all electrical flow' from the batteryisdisconnected so I can work on the system under that assumption - and Batrium is not needed at that point. If the system goes off via a critical even - again I don't need Batrium to be liveas I have the recorded metrics leading up to the shut-off that I can consult.
Having said the above, I was recently reminded that there is a 2nd power source besides the battery- e.g. PV power. I was upgrading the wiring and disconnected the battery as the 1st step and was momentarily shocked to see Batrium (and other draws)continuing to run... till I (duh!!) remembered that PV power was active. That's why there are breakers on PV input as well that must be turned off to work on the central control box.
