Mikethezipper
- Jul 7, 2018
- 121
Feeling pretty stupid right now.
So this whole time I was expecting that we'd want a higher balance current than what most boards offer (normal is 50mA or less, with some offering up to ~100mA). So I wanted to have an external board for running much higher currents that would be fan cooled. However everything I'm seeing now seems to be pointing to ~100mA being sufficient for even the large packs we are running. The idea being that if even larger currents are needed to balance a pack, there's something wrong and it should be addressed.
In that case I'll take inspiration from the Libresolar design - at this point I should have just basically used his whole darn board. He uses external FETS to pass the balancing current through a 33 ohm resistor that determines the balancing current. 4v thru a 33ohm resistor comes out to ~120mA (which is sufficient) at around 1/2W power dissipation. I'm not exactly sure how much that will heat up the board or resistor but it does concern me. So what I'm going to do is to get the largest surface mount resistor and use that on the bottom side of the board with copper under the resistor so it spreads the heat out to the ground plane. That way, if cooling is needed, it'd be easier to do on the bottom via a heatsink. Since I can just go with a standard size, anyone can choose to use a lower/higher value resistor to increase or decrease balancing current.
Considering CNY, I need to make the changes and order within the next couple days. Anyone got any suggestions for additional expansions or improvements in the next couple days?
Also Korishan, I looked it up and the suggested schematic does have a resistor between V5x and the voltage input.
