I picked up a 12kW automatic transfer switch (ATS) just because it was so cheap. I figured I could put it to use asI also have a 12 kW 48V inverter and a ton of 18650's (so I could make a DIY powerwall). How can I set it up so I can charge the battery bank from the grid/utilityduring off-peak hours (8) and run off battery bank during peak hours (16)?
P.S. - This would be for a couple of circuits in my home and of course beforehand I will figure out what theirenergy & power needs (to properly build the battery)
P.P.S. - The automatic transfer switch is aGenerac RTG12EZA1
P.P.P.S. - I also have Arduinos and relays as I imagine I may need them to control the switch's switching mechanism/state at off-peak and on-peak start times...?
