Trailer - Disable PIP for long term storage
OGITC: if you switch the system off during a time when the PV panels are still getting input, will that damage the panels? It is a concern with typical hot water solar panels, so people put in some sort of dump load or a cover. Just curious. I have considered doing something similar to your project, would like to know.
Thanks for the interesting posts...
Thank you for the thought. The 2s2p panels go to thru standard circuit breakers, are combined, and then on to the MPP. The disconnect procedure not only re-routes the AC around the PIP but also includes turning off the battery bank and disconnecting the PV input.
Lately the sun is high enough to reach the 4 x 300w panels on the roof of the trailer. Mid day - there is band of shadow from the roof of the house, killing optimal performance but beginning and ending 1/3 of the day they are in full sun ....
and producing pretty good power. Here's the kwh vs hours of the day from the PIP logs for yesterday. The dip in the middle is the shadow from the roof in the pic above. They're wired 2s2p length-of-trailer-wise - so 1 string is full sun and the other has shadow on both panels.
With the dip I'm getting 2kwh/day (June 2) and would expect to get 3kwh/day in full sun. I've been running the 9000 BTU heat pump maintaining 75F/24C 24hrs/day on a 48v@260ah 18650 battery bank and its keeping up.
The temp spiked this week to a few days of 100F/39C but will be back down to 80-90F/29C'ish soon. The system looses some ground at 100F but gains just a bit of ground at 85F. The trailer is 14x7 with 1" insulation + radiant tape *everywhwere* (ceiling, wall, floor, in the tail-gate, and all the nooks-crannies.
I'm really pleased at how well heat-pump / 1200 watts of panels / PIP / 14kwh battery is performing. With modest power management and good sun - this thing can actually run on Solar.
The DIY 18650 14s88p battery made of RING cells is performing very well. Sat for the last 4 months and just turned it on... and balance is holding at 20mv max difference same as 4 months ago.
**Lessons learned.
1) FLAT mounted panels means the rain/water pools on them due to the frame lip all around them and when the water evaporates the dust/dirt is caked on and is not washed off the way tilted panels are. Hadn't considered that... and would warn others to allow for some tilt for better self-cleaning.
2) The Honda EU3000is generator was converted to support Propane and it turns out you can still use Gasoline. The Gasoline mode will produce 2,200watts of continuous charging. The Propane mode will only produce 1,800watts... the motor isn't quit as powerful under load. and that's 20% less charging power.
I've been experimenting with the 120v is disconnected and the Trailer/PIP 3048LV has been running on solar + battery only. The mini-split has been maintaining a reasonable temp 24/7 - all good. However we've hit a hot patch - 106F/41C yesterday and projected 115F/46C today.
At these temps it can't maintain and the 48v (14s88p) battery is down to 51.8v this morning.
QUESTION: You can see my PIP settings below - what happens when the battery hits cut-off-voltage. with no 120v input?
I assume it will require external battery charge? and that it won't resume AC output until it hits "Back to discharge voltage"?
Yes. I have a few scenarios with the trailer and I just need to know what to set for different modes. For example:
1a) One mode is using the onboard generator to charge the batteries while driving - e.g. the generator goes to the ATS / PIP sees 'grid' and I want it to do the 20a max charging.
1b) An Alternate to this is just using the solar panels while driving to charge. The trailer is in shade so I can't test this very well right now - and surprised to see 2a charging (10a max) when when the panels only creating 100w in "Solar->Utility->Battery" mode. The 2a must be coming from the grid but why 2a instead of 10a?
2) Another mode is boondocking with sun and I want the solar panels to have priority - but maybe run the generator an hour or 2 to assist (with max amps flowing).
3) And bypass - where I have grid at a campsite (or just parked at the house) and bypass the PIP/batteries and leave it all turned off ---
*You're 3-position switch advice has solved this for me - thank you again for that!*
The good news is I can adjust parameters - but want to work out the minimum set of adjustments :)
I've got mine down to 1 setting for all the below.
1st up - I have Charger source prioirty = SBL&UCB + Output source priority = Utility->Solar->Battery. This works when AC input is off + when AC input is on it will still let the PV thru if I throttle the Max AC charging current so that Max AC charging current + PV <= Max charging current (to the batteries). In my case 2a + PV = 13a = 15a and is <= 40a.
I have a honda eu3000is and discovered that Max AC charging current = 20a (in conjunction with Max charging current = 40a) is the max the generator can sustain before the engine overloads / runs erratically. This gives me ~ 2,200w of continuous AC charging.
The reason I have Max AC set to 2a (right now) is that if I left it at 20a (for max generator charging) it would be 20a + load = overload on the 15a circuit I have the trailer plugged into at home. This might be true at a camp-ground as well. But with 100% generator = I can set it up to 20a for max charging.
I only need to alter the Max AC charging current from 2a to 10 or 20 or xxx till I reach the max the generator can do. But remember - its Max AC charging current + load - so you're situation may vary. While driving, you're load should be minimal so max AC amps your generator can handle.
Just leave the generator off with settings above. The PV will surge in with no 120v input.
Since you'll likely have load, you might want to pull on Max AC charging current - to 50% of your generator max to both charge and leave room for active loads.
I hope that helps and I'm not sure this is the 'only way' - its just what I'm doing so far :)
A side note - I took the 7,000lb trailer out for a 1st 20mile run the other day. It only weighs 3,800lbs (good) and the PIP / mini-split ran just fine the whole time. The mini-split is silent inside and out. The surprise was the PIP is not that noisy - perfectly OK for inside the trailer!
For example:
3) And bypass
Replied to these questions 2 posts earlier with a pic of my settings.
They were a spammer, they've been removed.
After a year of work - "The Trailer" took it's maiden overnight voyage! Used 5-6kwh in 24hrs for full 24hr mini-split comfort + dinner (full range of appliances). The 14s88p (260ah) battery went from 56.0v down to 50.0v low (52% DOD per my chart) and back to 52.0v with a bit of sun on panels during travel home.
Overloaded the MPP Solar 3048 at one point (mini-split + hot-water + hot-plate + microwave) and had to turn it off + back on to reset as I didn't know what to do - but that worked. The system has 30amp AC circuit breakers (10awg wire) - so the the PIP overloaded before they tripped as it tops out at 25a@120v.
Really happy with the 18650 battery and the PIP :)
How exciting! In my system I have noticed that the BMP low pack voltage protection is almost always what shuts off first from high voltage drop under full load, even with full packs. Once I upgrade to the DIY BMS I am hoping to be able to set it up to have a lower under load shutoff protection vs resting voltage protection.
How exciting!
Thank you :)
Yea... a high voltage drop under full load would mean the battery is smaller and load is larger. For example, if an 18650 battery drops from 4.0v to 3.6v 'instantly' on a load, I'd say the load is extreme for the battery size. Can you increase the size of your battery or lighten the load?
For example, the trailer battery is 14s88p @ 260ah and is subject to a max of 3000w which is about 700ma/cell. On average things are running at 350ma/cell... so voltage drop is not consequential as this is within standard discharge specs of the cells.
I have the PIP set at 49v low (3.5v/cell) whereas the BMS is at 3.3v low and the PIP hi is 4.0v/cell where the BMS hi is 4.17v/cell. I use the PIP min/max as the operational control for low DOD... and can change it a bit as needed like going up to 4.1v/cell for more DOD if I boondock. The BMS is fixed and offers the full-stop shunt-trip protection.
Yep I agree my battery is too small/poor quality for my desired peak load. I am currently building a 100p7s pack with fully tested cells and am hoping that will work better although I am also hoping to upgrade to a bigger inverter so for that I think I will need the second pack I have tested but not assembled yet. I am designing the packs to operate at about 1A per cell.
My current setup is one I inherited form a fellow hobbyist and I don't plan to keep up the design and am retesting all the cells since they have sat at full charge for a couple years since the last testing and there are lots of ones I would consider B grade for my standards, Under 1800mAh, Sony cells... I haven't done supper detailed tests since this current setup is "temporary", I think we all know how that goes :) Based on my basic calculations I am pulling about 3kWh AC so about 120A DC and it shouldn't be more than 1.5A per cell peak(I think there are about 180 cells in series assuming I haven't blown too many cell level fuses yet). I am actually thinking a not insignificant part of the voltage drop is from wire losses. Most of it I am sure is do to the bad cells drawing down the pack but I currently only have two parallel 10AWG wires from the batteries to the inverter and while the distance isn't long I am pushing past the design specs of the wire and it does get warm(but not hot) to the touch when at peak load. Again that whole "temporary" thing but I plan to have 1/0AWG wire for my new packs and inverter so that should handle 250A.
As a side note you are always talking about PIP and I have been to lazy to figure out what exactly you are talking about. It is pretty easy to deduce it is some sort of protection circuitry though.
1a / cell is pretty hefty for regular laptop cells - most are more in the 0.5a standard discharge range. What cells are you planning to use?
Just take your load and divide it by the number of cells in one of the series packs. For example, let's say you have 7s100p and you're max load is 3000w. 3000w/24v = 125a. 125a/100p = 1.25a/cell. Unless a cell has specs for this (standard discharge) it will pull down the voltage.
I would guess it's the amps/cell that is dropping your voltage rather than wiring or a few cells.
PIP is a (loose) short-hand term for an MPP Solar Off-grid unit. https://www.mppsolar.com/v3/pip-series/
Although it has been pointed out to me in the past that PIP(s) are not all off-grid and in the link above - they are 12v/24v whereas my MPP Solar 3048 is 48v.
I think I just like the term "PIP" because of @hbpowerwall and that bit of Australian envy over their the cool accent and figures of speech. :)
This post is a little trip down memory lane - to my very 1st DIY lithium-ion attempt.
The story starts because I just Installed an ARB Awning on the trailer for our outing this week....
The awning came with 12v powered LED lights, so I need a cigarette lighter 12v source....
My very 1st project over 3 years ago was to convert a DURACELL powerpack 600 (which has a 12v cigarette lighter plug) from lead-acid to 18650...
I built an UltraFire 3s32p 18650 DIY battery with no BMS (AGH!!!). You'll notice some volt meters hot-glued on top - which is what I used to make sure I didn't overcharge. Bought the UltraFire cells on Amazon and they had about 1100mah capacity each (wow).
After sitting for 3 years the battery was down to 6.0v and when I opened the unit, I noticed the + screw was pushing against a cell covering (which is a short just waiting to happen) - AGH!!!
Anyway, much wiser these days and tonight I replaced this disaster-waiting-to-happen with the 16ah version of Miady LifePo4 similar to this for about 1/2 the price of the 96 UltraFires above:
Simple, easy, times have changed and instead of 'difficult' 3s voltage range trying to act as 12v battery - the LifePo4 matches nicely and has it's own BMS :)
I'm pretty sure you need to switch both neutral and the phase.
The neutral is freeflowing inside their inverters or atleast should be in most of them.
Neutral in my thinking is one of the single-phase 120v wires - e.g. the white one. The black is the other wire.
The ground is a separate, 3rd wire.
They even have a larmcode for neutral grounding issues.
I don't have any codes or alarms.
Thats why i had to go for 5 wire setup instead of 4 ie separate ground from neutral so i could switch 4 wires instead of 3 in the ATS.
Just get a 2 pole 1-0-2 switch.
You can even have a manual one in your case.
Or actually in your case you need a 3 pole 1-0-2 switch.
In my case, the grounds are all wired together and all go back to the 'grid provider' ground. When plugged into the house, its the main panel where ground is tied to neutral (per US code). At camp grounds, I don't know what they do - but hopefully the ground is wired to a ground somewhere.
So I don't need to switch the ground wire as far as I understand - its just a common/shared ground everywhere.
I'm no expert and interested in your comment as I don't know what I'm doing - if you could explain a bit more why it matters in my case I'm certainly interested.
To recap, I have PV on the roof coming in and external AC coming in and 48v battery. These are my settings:
"Max charging current" (above) at 40a is battery amps max and 40a * 54v = 2160w of charging. I leave this 'permanently' - matched to max the generator can do. PV is <40a so it's not restricted. The "Max AC charging current" overrides (throttles) this setting.
"Max AC charging current" is the setting I change. Its currently at 2a (240w charging) / sitting at home in dry-dock because
1) This is the lowest setting,
2) I don't need very much battery charging in dry dock because the 120v grid is running things, and
3) I don't want to add 2000w to the 120v circuit from the house for charging.
Note: I can bump this up for rapid battery charging in prep for a trip - just have to be mindful that I'm plugged into a 20a circuit at home so 10a = 1200w and 20a is too much!
For example:
Grid (generator) 20a * 120v = 2400watts. 2400w/48v battery = 50. You might want to use 50a instead of my 40a for "Max charging current" as a permanent setting.
Then, simply bump "Max AC charging current" to 20a and then back to 2a when finished.
Note: If you set "Max charging current" to 100a and allow that to pass thru by setting "Max AC charging current" to 50a, then you'll just overload your generator. So I use "Max charging current" to avoid this.
The "Max AC charging current" has no affect on PV with the other settings above.
Its the 40a or 50a in your case setting that matters. 50a would be plenty unless you have a HUGE array :)
My MPP Solar is 25a max. My 120v grid circuit at the house (and typical campgrounds) is 20a or 15a. At 2a (the minimum) 250w are directed toward battery charging. At 10a then 1200w are directed to charging - which doesn't leave much on a 15a or even a 20a to run mini-split, microwave etc. So I typically bump AC amps when I'm ready to charge and not run much else.
The "Max AC charging current" has no affect when boondocking as there's no incoming Grid.
Then it's off and settings don't matter.
Cool! Thanks for the kind words.
Just finished the base install of battery #2 for a total of 27kwh in the trailer. Still have to button up and make wiring more secure.
Our 7 x 14 trailer has 1" insulation but we use the tailgate as a 6ft x 6ft bedroom - metal framework + 18mil tarp. This tailgate extension is not insulated - just 18mil of tarp.
This 2nd battery let us do a full 24hrs on the mini-split (electric heat) + hot water, refrigerator, starlink/computers/TV, all electric kitchen down to 30F lows. If we use the heat-buddy we can do 72+hrs (3+ days). The heat-buddy consumes 1 gal of propane / 24hrs with ~30F low - ~50F hi. Additionally we can close the door between the insulated trailer and the tarp tailgate bedroom and let it be cold most of the day if we need to conserve.
The original Bat #1 is 14s88p (48v@260ah) above the cabinets on the passenger side (left in pic). Put Bat #2 is 14s87p (48v@52ah) on the driver side (right in pic) wall behind the lounge chairs. Each one is ~150lbs = 300lbs of battery in total.
Closeup of Bat #2. It's raised up so the lounge chair pedestals will still butt up against the wall (under the battery) so we don't loose an inch of floor space.
Charging and balancing.....
PHEW... is such a relief to hookup the longmons correctly the 1st time and see it all working.
Here's a pic of the tailgate bedroom to help clarify the situation
FYI - The 18650(s) + Batrium/longmons + MPP Solar + all the equipment has held A-OK on very bumpy roads on more than one occasion. Wash boarding on gravel roads is sooo annoying and one road had 1foot gaps in the pavement every 100yards. Which means you have to slow to 5mph to reach a campground 5miles off the main road (AN HOUR) OR go 40mph and shake the living daylights out of stuff. Have done both and the trailer equipment survived, but..... it's the trailer build is not made for extreme shaking so I try to resist.
Got the new battery balanced in with the original and charged up for our next camping trip, however...
1 - 14 packs are up high above the cabinets and 15 - 28 packs are down low against the wall (1" R5 foamboard insulation). It's 35F/2C outside w/mini-split maintaining winter storage temp of 63F/17C inside.
Notice an above cabinet #1 pack is 55F/13C per Batrium Longmon but a low wall pack #18 is 41F/5C. That's a 21F/8C differential from chest height temp in the trailer to the floor / outer-wall.
The heat from the mini-split doesn't go to the floor easily and the cold could be enhanced because directly above the trailer wheels there's just the 1/2" plywood over a thin metal plate with wheels behind. There's no 1" foam board / insulation in those few square feet under the fender.
Built the battery enclosure to have good air exposure from the trailer but 41F/5C a little colder than I would have liked but 41F/5C is >freezing and so the battery should operate at low stress A-OK for both discharge and charge.
However, this is a low cycle count battery (10 cycles / year) and at that rate it can last a long time calendar wise.
It's stressful for me to build/install a 100% DIY battery in the trailer... as it takes trips, and shaking, and using it over time to gain confidence. However, the 1st battery has been no problem, so that helps a bit.
Been out twice using the new battery and it's working great! Looks like the MPP Solar 3048LV inverter is ~85% efficient. We do full electric - e.g. mini-split, cooking steaks on George Formun, K-cup coffee, and InSinkerator hot water. Operating in the range of 4.15v/pack max charge down to 3.4v/pack cut-off which is ~85% of theoretical max capacity = 23kwh.
First 'new battery' overnighter low 36F / hi 55F and we consumed 15kwh over 24hrs. At 15% inverter loss, that's ~18kwh of battery out of ~23 available. Not bad and near our original goals... Takes more battery for HEAT (even using a mini-split) than I ever imagined when starting out.
Second 'new battery' overnighter next to the famous Roque River in Southern Oregon was milder temps (low 45F / hi 65F) and consumed only 10kwh over 24hs (and saw some wild turkeys). Getting close to 2 days w/mild temps - fantastic!
Battery install is rock solid, no loose cells/packs/wires or issues due to traveling down the road. 18650 DIY batteries seem quite sturdy.
For a propane comparison, we've found our heat-buddy on low (~1 gal / 24hrs) keeps the setup nice and warm at colder temps (low 30F hi 50F). So it's roughly 1gal propane vs 18kwh of mini-split for similar heat.
However, the heat-buddy causes considerable 'water vaper/drops' in the trailer over a continuous 24hr period and doesn't have a thermostat so the mini-split is 1st choice for us :)
Update - finally able to get a Chargeverter V1 for the trailer. This will let me hook the generator directly to the Chargeverter for charging (instead of going thru the MPP Solar) and leave the full 3000w AC from the MPP Solar available for use in the trailer when boondocking. K-Cup, hot-water, toaster, tv, starlink, computer, hot-plate, Insinkerator, mini-split all make 3000w the bare minimum for parallel use of things.
Chargeverter can do 50a charging on 120v - e.g. a little over 3000w of charging per the user manual.
Originally we went with a duel-fuel Champion 2500 but, it maxes out at 1000w of AC - e.g. ~17a on the Chargeverter. Disappointing.
So we upgraded to the MaXpeedingRods 35000w generator and I had it at the full 50a on the Chargeverter..... but it was maxed out so 45a is more likely. 45a * 57v = 2565w of charging and 2900w load on the generator.
The Chargeverter metal case didn't get that hot using 120v and mounted vertically BUT, the yellow sticks out like a sore thumb - just not many places left in the trailer to stash things :)
