There's no need to destroy these , they will still work fine in torches etc ....
You can weigh them , around 40gm shows they are typical cells and no information can be gained from cutting them open ...
Taking off the plastic sleeve will show the printed numbers on the cell ...
It would be interesting to know what ultrafire are using now ... 2 years ago the 5 I looked at all had spot welding marks under the end caps.
If your cells show signs of leakage , perhaps they are now using old or faulty cells .
Nothing dangerous about dropping them in water , even salty water .... no lithium metal inside ...Salt water is an interesting , easy and original way to MAKE SAFE cells , if you have a lot of them. ... I don't know why I didn't think of that one !
I have a dozen reject cells immersed in water for a month already , as an experiment to see how quickly the can will rust away allowing access to the goodies inside .
I confess I've never tried salt water ... will do so now with a fully charged cell ...I'll be back.
EDIT .... Approx 40gms salt in 200ml ....As we should expect , on contact with the solution bubbles were seen from the +ve and -ve end ...
electrolysis of salt water produces hydrogen bubbles on the -ve electroge and Chlorine on the +ve and makes the solution change into caustic soda .
After a few minutes a green cloud was apparent in the solution, only at the +ve terminal , on agitation this separated somewhat into brown and green components , this would be the +ve electrode reacting with the chlorine given off there.
After 15 mins it's still bubbling away and the solution is murky with brown and green precipitants .
So it is a safe way to discharge , just leaves a lot of mess behind .
