(USA)Lightly used LG18650MH1 (Blue) 3200mAh 10A 3.63V 11.62Wh = $1 for one or less
Status
Not open for further replies.
SolarSolutions
LG18650MH1 18650 cell,3200mAh 10A 3.63V 11.62Wh GENUINE CELLS
These cells are in excellent condition, testing at 95% (or higher) of the manufacturers rated capacity.
Please take note, these cells were extracted from brand new battery packs, so they have spot weld marks and leftover nickel from the welds on the positive and negative terminals (see pics). This does not affect the cell's performance in any way, you could spot weld or solder over them or remove very easily.
You are getting brand new quality & capacity, for the price of "used" cells which would normally have noticeably decreased capacity.
Most of our cells still test over their rated capacity, though to be on the safe side, we say 95% or higher.
Besides the spot weld marks, they are otherwise "new" in performance and quality
Rest Assured, Always 100% Authentic, GUARANTEED!
SHIPPED PRIORITY MAIL
SAME BUSINESS DAY SHIPPING
PACKED BY A CERTIFIED PACKAGING EXPERT
SHIPPED FROM USA
If you're interested in placing larger bulk orders,
I have a large stock of these cells,
feel free to contact me anytime!
Below are full specifications, fell free to ask questions that weren't covered here:
LG MH1 SPECIFICATIONS TABLE
Brand: LG
Model name(s): LG18650MH1,INR18650MH1,INR18650-MH1 ,ICR18650MH1
Manufacturer full Name: LG ?? (LG Chemical)
Origin: South Korea
Weight: 49.00 g
Diameter, max.: 18.40 mm
Height, max.: 65.10 mm
Voltage, charge max.: 4.20 V
Voltage, nominal: 3.63 V
Voltage, discharge end: 2.50 V
Capacity, max.: 3200.00 mAh
Constant charge current, max.: 3.10 A
Charge constant standard: 1.55 A
Discharge standard: 620 mA
Max. continuous discharge current: 10.00 A
Peak discharge theoretic, 4 sec: 17.5 A
C-rate (charge, max.): 0.97 C
C-rate (discharge, max.): 3.13 C
Watts (charge, max.): 11.253 W
Watts (discharge, max.): 36.3 W
Energy, max.: 11.62 Wh
Density volumetric theoretic: 672 Wh/L
Density gravimetric theoretic 237.00 Wh/kg
E-rate (charge, max.): 0.97 E
E-rate (discharge, max.):3.12 E
Chemical abbreviation: NMC
Cathode: LiNiMnCoO2
Anode: carbon
Remark: Ni-Rich
Standard charge: 2.5 hours
Rapid charge: 2 hours
Storage (less than 1 month): -20 60 C
Storage (less than 3 month): -20 45 C
Storage (less than 1 year): -20 20 C
Temp charge, min: 0.00 C
Temp charge, max: 45.00 C
Temp discharge, min: -20.00 C
Temp discharge, max: 60.00 C
Internal impedance: 7 m?
Here is an in-depth data sheet about the cell and it's testing and origin.
https://voltaplex.com/media/whitepapers/specification-sheet/LG_MH1_Specification_Sheet.pdf
I am located in the West Coast, shipping rates for USA only are the following:
Minimum order: 15 pieces at $1 a piece. $5 shipping.
From 15 up to 50 = $6 Shipping
From 50 up to 170 = $12 Shipping
From 170 to 300 = $15 Shipping
Any orders over 300 = Free shipping.
Any out of the country orders would have to be calculated on the spot, so inquire via PM's.
can provide more detailed descriptions or photos if needed. At this moment I have about 2000 cells available, will have more as soon as I sell this batch. Price will either drop or increase depending on demand.
All transactions through paypal only with moneyback guarantee if the quality is subpar.
No ultrafire scam stuff, these are honest, hardworking 3200mah cells.
Approved. Please move images from links to posted here. Images in Marketplace should be immediately visible to potential buyers.
Added note: Do not advertise YOUR cells on someone else's Marketplace Thread. Your other post was deleted for this reason.
One order of 450 cells and another of 100 cells and one bms was sold and shipped, reviews are coming soon.
SolarSolutions said:
lesero57 said:
I'm interested. Check PM
Didn't get a pm, sent you one instead
That's because they are spammer. They've been deleted.
Hi guys I bought 450 cells shipping was very fast usps 2 day, all cells received were exactly as described and the same as the pics. So far I have built 1 - 72v pack of 300 sells (20s15p) just finished it up last night everything is working good. I took a random sample of about 40 cells, I selected cells with a 3.2 v reading or less to cycle charge of the 40 , 32 of them cycled to a full charge of 3200-3250 mah, 5 were in the 3100-3150 range and 2 - 3000 to 3050 and 1 cell had a very high ir charged to 2950. After a 2nd cycle 6 of the 8 low cells were up close to 3200 (3150-3200) the worst 2 Im doing a 3rd cycle now to see how they do. I know there other better methods to test this is just what I tried. For the price and the quality Im seeing these are great used cells! Im planning on making another purchase of these soon. I have attached some pics of the cells in the box they were shipped in, they were bundled into 40 cell blocks most of the nickel tabs were removed, blocks were wrapped in plastic wrap for shipping . Seller had great communication too! Ive checked all 450 of the cells I have purchased and there was no dead cells in the whole batch, seller included a few extra cells too just in case I had a bad one. Great experience with my order, fast ship, good communication and for the price these are a good deal.
I got some of these from same seller and looks really good for the price. Will attach photos, but those are in very great condition and also good internal resistance according to my Liitokala chargers, around 30 to 50 average.
and capacities around 2850 to 3150, not so bad. Will get more if its possible!
skinia66 said:
Hello . I'm interesting can you send me to Nederland?
Yes, but it will probably be very expensive. I'm shipping usps from Los angeles, one cell is 49 grams, you can do the math yourself.
Not only that, international shipping, they may inspect the package contents. If they do, they may deem the package unsafe for transport and hold it. 100Wh is the maximum per package that is allowed for lithium not in their originally manufactured casing and device they are to power.
How much would it cost to ship to Canada? You can ship via USPS, it's generally the cheapest. For 70-200 cells.
Luis7949 said:
Estoy interesado en comprar celdas conqui y como puedo hacerlo
English only, please
I have sent you a PM an email and replied in this Posting and have not received any reply.
Are you still with us?
Status
