Using e scooter batteries for powerwall
Longbush Powerwall
Hi guys. My recycler can get me an ongoing supply of used e scooter battery packs. They are the Eve brand battery with 20 in a pack, around 2500mah per battery. Has anyone used these packs for a powerwall and connected them up. They are not easy to break apart so interested if they can be used still joined up.
Cheers
Paul
Cheers
Paul
Yes you can. Here's youtube from @jehugarcia where he creates a busbar to plug them in 'as is': Simple DIY Powerwall using $1 LG 18650 eBay Cells -[size=small]
The problem with 20cell e-bike packs is their 36v (nominal) voltage range -which limits your choices forcharge controllers & inverters. Things are just 12v, 24v, and 48v oriented. However,beyond having to search for voltage rangecompatible equipment - there's no technical issue with a 36v battery bank :)
You also need to consider why they landed at the recycler in the first place. From my experience, such packs often have 1 or more bad cells.
Also, if it has separate charging and discharging connectors, tying multiple batteries together in parallel may be a very bad idea. Depends on the BMS.
Thanks guys for your feedback. May try recovering them from the packs instead. They seem to be eve batteries and the handfull I have tested came in around 2600 mah.
Paul
