amerrigan
- Sep 26, 2019
- 23
Been offered some Valence Power U-Charge P30-36C (LiFEPO4 36v 30ah) units relatively cheap here in the UK and am considering buying, wondering if anyone has heard or used these units before?
It seems to be an older model and no information available on https://lithiumwerks.com (the manufacturers) website, my scratching about for info:
Contains 144 x 26650 LiFEPo4 cells (12s12p)
Inbuilt BMS system (connects to Valence monitoring software via relatively easy to make USB adaptor)
Rated 38.4v 1152Wh
Max input 43.8v
About 18Kg each
Hopefully someone here knows more than me on these, guessing other than wacking the right voltage in via a proper Lithium charging circuit there's no special requirements?
Rated 38.4v 1152Wh
Max input 43.8v
About 18Kg each
