Ant?nio Pereira
- Jan 20, 2018
- 17
Hi, I'm new to this forum.
I'm planning to build a ebike battery from used laptop batteries, on the process of charging, testing, sorting, etc. I've found something that is completely different from anything I found on the internet.
Basically everyone says that cells over 3.5V are fine and under 3V are most likely damaged.
In my findings I found the completeopposite, for example, I have a Panasonic CGR18650CA that had an original voltage on the pack of 4.06V I thought it would be a very healthy cell.
I charged it to 4.2V and tested for capacity at 1A discharge, to my great surprise in less than a minute it dropped to 3.0V showing a 20 mAh capacity, the cell quickly recovered the voltage to 4.07V after the test finished.
On the other hand my best testedcell so faris a Panasonic NCR18650 that wasa 1.81V cell when removed from the pack which has a capacity of2647mAh at a 1A discharge rate (91.28% capacity).
Anyone care to comment?
