What size lugs
leemc82
Hi my very first post. Hope everyone is well. My question is before I order the wrong size. I have 25mm earth cable copper wire very tough to manipulate. The biggest lug I can find is a 50mm would this still fit 2x 25mm copper cable
Might help if you untwist each bunch an inch or so, then make one round bunch of the strands so it fits in the lug more easily?
Whatever lug you use, try to find ones with the hole size already matching the bolts, enlarging the hole not good (not allowed in regs as it reduces current handling).
paulie
Great forum. I am still in the early stages. Slowly building up my system which will be 80P 7S initially. For those of use who are metric lol.
I am using 10mm2 earth cable stripped and 16mm lugs with a hydraulic crimper. Once I have the 7 packs all done like this, I will start soldering the fuse wire onto the cells.
leemc82
I'm using SC10-8 copper lugs for my 10mm2 wire (7AWG) connecting series. The cable/lug choice is based on my initial project where I defined:
- Single battery will be 14S20P, average cell around 2100mAh, total capacity around 42A;
- At any time a single battery will charge/discharge no more than 20A (so each battery will have 20A fuses and 20A DC MCB);
- Four batteries 14S20P will be in parallel, at any time: one out of four can go in maintenance leaving three batteries operational.
[ Note: on the first 14S20P battery I made I used SC16-8 lugs, actually a bit too big, now I switched to SC10-8, the right size. ]
