Personally I think Redpacket's post should be nominated for the "Post of the Year Award"
Sometimes it takes a wakeup call like the one being discussed to re-evaluate how we build our batteries.
A Li-Ion cell no matter what form factor is an energy storage device. Think of it as a small gas tank. Petrol tank for the non US.
A gas tank stores gasoline which is a form of liquid energy. In its liquid state it is dangerous but also quite manageable as long as you follow certain guidelines for containment and safety.
The same goes with a Li-Ion battery. In its pristine state it is a very efficient energy storage device. Happily accepting electrons to store and on demand release them. Now it will do this give and take in a safe manner if certain rules and guidelines are followed. No question we see it everywhere in all kinds of appliances. Our watches on our wrists have a mini gas tank( li-Ion button cell) in them. I certainly don't have a fire extinguisher in my pocket just in case my watch catches fire. Now I know this is an extreme example but it proves the point. Li-Ion battery building is not a "Just throw it together and it will work" exercise. Careful planning and most important proper cell analysis is paramount.
I am not saying everyone should do this but I keep a record of every cell that goes into my battery. I know the initial voltage, the initial AC IR, the mAh results from a capacity test, the voltage and IR after the capacity test, the voltage and IR of the cell after a >25 day SD check and the voltage and IR of the cell as it goes into the final build sometimes a couple of months later. Any cell in the final check that doesn't pass these tests does not make it into my powerwall battery.
Overkill you say?
Maybe but I can tell you one thing I sleep well knowing what the condition of my cells are. Also in the future
if I have a catastrophic failure I should be able to determine what cell/s may have caused the problem.
I also agree with monitoring your battery and the packs in a very close manner. I think Batrium does a very good job at this but as far as visualization over time the reporting is lacking. Not that the data is not stored just that it takes a bit of fanagelig to get the data into a visual format for easy analysis.
Weather and Sun have been somewhat dismal in the US NE but here is a chart of my battery and the packs for the last 7 days. Can you pull that up in a batrium interface? No, but it can be collected via UDP, node red, influx and grafana. If need be I can go back to the beginning of the battery installation and extract that data in visual format. If there was a pack within this battery that has a SD/Heater in it I think it would be obvious especially at night when the battery gets drawn down to cutoff voltage. I would see a large voltage drop over the evening stretch rather than a nice even correlation
View attachment 23185View attachment 23187
