harrisonpatm
- Jan 5, 2022
- 401
As I am doing my primary charging of salvaged laptop cells, I have had about 4-8 cells in the past week that my Opus charger is trying to overcharge. These have almost exclusively been the red Sanyo cells. They have passed my first voltage check, being recovered at above 3V, meaning none of these are 0V or very low voltage cells that I'm trying to recover. So I rotate them into the Opus charger at set it to 300mA current. What happens is, the voltage will increase to somewhere between 4.10V or 4.15V in 2-4 hours, depending on the cells starting voltage. Then the charger will go off into it decreasing current, which is to be expected. Except it doesn't end. I pay attention to the accumulated mAh, and it gets up to 3500-4500 mAh (which is obviously ridiculous) when I pull it, while never going above 4.15V. They get warm, not hot; around 30-40 degreees C. I also use Liitokala chargers, and they never exhibit this behavior, despite putting similar "questionable" cells through them. I also process other red Sanyos that don't exhibit this problem.
I will of course not be using these cells, set them aside to discard, but I was wondering if anyone else has seen this behavior and know why this is happening. On one of these occasions, I wasn't paying as much attention as I should have and the accumulated mAh got up to 5500! Clearly this is either a bad cell or a charger glitch. I know the Opus chargers aren't supposed to be dead accurate, and I have gathered from this forum that the red Sanyos can be glitchy. Just want to understand what's the specific issue here. .
