Riplash
- May 27, 2018
- 71
Hello All;
Have any of you experimented with spot weldingfuse wire like Jehu did with 1/4 watt resistor legs? I would like to do the same thing because I can rapidly spot weld the glass fuse legs to the cells and solder the other end to the bus bar. I would like to use heavier wire on the negative side as bus wire going from the cells to the bus bar, and would like to spot weld the wire to cell end, and solder (or weld if the materials allow it) the wire to the bus bar. I also would like to use a smaller gauge wire like fuse wire the same way Jehu used his 1/4 Watt resistor wire. I could buy lots of resistors like Jehu did, but being the nerd I am I want the wire specifications and would rather buy a roll of wire rather than cutting off the ends of resistors for the wire?
Since the resistor leg wire, and glass fuse wirecan be easily bent and soldered I am guessing they are Nickel or Nickel Iron Alloys. I am finding all types of possibilities that they could be, and I am wondering if any of you have researched this. The material I am looking for doesn't have to be the same as the resistor leg wire, I just want it to be easily spot weldable, solderable, and be able to be used as bus and/or fuse wire.
Thanks,
Ryan
Thanks,
Ryan
