lifepo4_powerwall
- Aug 11, 2018
- 10
I am installinga Lifepo4 24v system to run my 6000w/18,000W surgeAIMs Power inverter to run my house when I lose power after the next hurricane in Florida.
I have mounted battery banks on the wall and calculated the wiring sizes but needed someone to check it over before I order the wire. I checked out the FAQ on wire sizing.
If you look at the picture each bankof cells is 12v, so I am putting 2 banks in series to get 24v. Each bank will provide 228ah or 452ah per pair (based on 3ah per cell x 76cells per bank).
The pair of banks on the left will be connected to each bank pair until the wiring gets to the inverter so the amperage will increase.
So for leg 1 I calculated 452ah / 24v = 19amps, so a 12AWG wire will work, the distance from one leg to anther is 1ft.
leg 2 = 19 +19 = 38amps = 10AWG wire, 1ft red and black
leg 3 = 38 +19 = 57amps = 10AWGwire, 1ft, red and black
leg 4= 57+19 = 76amps = 8AWGwire, 1ft, red and black
leg 5:I also have a 40 cell bank of headway 38120 cells under the inverter which provides 10A each or 400ah with 24v which generates 16A and needs a 10g wire, 3ft red and black
Now I need to join the leg 4 wire to the leg 5 for a total of 76+16 = 92A which needs8AWG.
The AIMS inverter docs states itneeds 4/0 wire for 6000w at 24v which is a big jump up from 8AWG!
Are my calculations correct? What happens when I get a surge demand of 18,000W through the inverter? Will the calculated wiring gauge handle the load for 20 seconds?
