Wayne's World
- Jan 28, 2020
- 84
How are you going to connect them. - Will each new 1s pack be in parallel with its original, and so make new cables from one pack to the other, or a completely separate 14s system, and parallel the entire system at the overall + and - ?Wolf said:Extra capacity is just a matter of another 14 packs tied in with the existing packs. Not sure what you mean by that.
I'm thinking of using either XT or Anderson plugs for each pack, and making Y adapters to add extra 1s packs to each. Once I have at least 2 packs in parallel, this would allow easy removal of a pack for servicing and not interrupt the power supply, albeit that remaining pack will go out of balance if left by its lonesome too long. Hence the benefits of having a spare pack or 2!
I see you went with the Batrium 4(?) that uses Longmons. Any reason why that and not the later versions. I've watched a couple of their vids but not yet across the application for each.
I saw in one of your photos that you had a bunch of different cell testers. Did you find varying results and how did that effect your database and cell selection criteria? I'm presuming you've got a thread or videos dedicated to this?
