thanks for the replies! I changed the 360 resistors with 330 on the 1 module, so all are 330. the ones i removed, i used to repair the other one with the one damaged. now it all works!
Also, the modules are a bit "off" with voltage read, but i know these should in theory be calibrated.
But from what i read, it does not really matter. consistency is more important than accuracy.
Yes. I think you need a sample size larger than five, though. At least ten or twenty. (It's been a long time since I took statistics, but I imagine that if you get to twenty data points through both the 330 and 360 testers, you'll start to have some meaningful significance in your data.)I bought more modules, and these all have a 330 ohm resistor. So i should get like 5 cells, test them on the 360 ohm ones, and then the 330 ohm ones?
