TheBatteries
Administrator
- Oct 8, 2016
- 2,127
Data References:
http://www.meircell.co.il/files/Panasonic CGR18650CG.pdf
Pictures:
Brand: | Panasonic |
Model: | CGR18650CG |
Capacity: | 2250mAh Rated |
Voltage: | 3.60V Nominal |
Charging: | 4.20V Maximum 1500mA Standard --- mA Maximum |
Discharging: | 3.00V Cutoff 430mA Standard 4330mA Maximum |
Description: | Green (Light) Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
