Samsung ICR18650-28A Cell Specifications
TheBatteries
Administrator
Brand:Samsung
Model:ICR18650-28A
Capacity:2800mAh Rated
Voltage:3.75V Nominal
Charging:4.30V Maximum
1400mA Standard
2800mA Maximum
Discharging:2.75V Cutoff
560mA Standard
5600mA Maximum
Description:Purple (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Samsung ICR18650-28A.pdf
Pictures:
I today liberated 6 such cells out of an original hp battery. It wouldn't charge because one of them had its CID tripped, which I reset. All cells were around 4.1v, even the inactive one. All measure around 2100mAh at 1A discharge. What do you think, should I keep the tripped-CID one?
I wouldn't use the CID-tripped one. You don't know why it popped and it popped for a reason. It's best to error on the side of caution/safety.
If the CID has been activated you should recycle not try to repair.
