jdeadman
- Mar 28, 2017
- 967
Well it's about time I posted about my new plan.
I'm building a home wall to work towards using less from the Grid and basically playing. In my other build I built a camp powerwall of sorts in a 7s configuration. For the home wall I'm still debating on going 48v or stay with 24.
But that will come later when I finalize my inverter choice.
But for now I'm still processing a huge pile of 18650 that i got off a guy from one of the Facebook groups that lives about 5 hrs from me in the states.
I picked up 282 lbs of cells! Ornabout 128kg mostly processed. I figure about 2800 cells.
So I then picked up 3 of the newer opus testers (bt-3400) and immediately modded them with fans blowing in the bottom to remove the heat from inside the case and to cool the cells .
So far from what I collected before the big haul I had processed about 600 cells. Now I'm up to 1100 tested and that let me use repackr to organize the first 24 packs of 14s40p.
I chose 40p as I like to be modular with my systems as I learned in building my camp wall. Where I used 8p holders and attached those in parallel with 6 others to get my 56p overall. This lent itself well for any issues with a single pack I could just pull that one small pack out with the walk running and I had a couple spares to put in place
So I will have something similar for my home wall. I just need to decide 7s or 14s
I'll update this thread as I go along
