MonkeyThink
- Mar 7, 2019
- 4
Hi All.
I like the idea of a portable power source but larger than a standard 'off the shelf' power pack, to charge phones and other devices while I'm out & about and working remotely.
I'm thinking of something the size of a house brick (215mmx 100mm x 70mm ), which should be able to incorporate 40 x18650s depending on the choice of what else I include inside., which should end up about the 2kg mark. I'm aiming to use cells of at least 2,000mAh or better.
At the moment I'm considering a 4s 10p design built using a 4s BMS to charge it, which means I can power it from pretty much any laptop power supply.
Output: Using an 12v car cigarette lighter type device to convert the voltage from the nominal 14.8v to 5v USB. I like the look of the ones which incorporate both a voltmeter and USB 3.0 / Fast Charge / PD so that I've got all the latest options available.
Does anyone know how efficient these type of devices are? Or is there a better option?
Is there a different design that would better/more efficiently use the 40 x 2,000mAh?
Other considerations:
-I could just parallel all 40 cells and then boost/buck the 3.7v up to 5v, but charging would become slow. Would this be any more efficient?
-If I made it 5s8p I could also tap off 20v to directly feed my laptop and/or incorporate a fully fledged 20v USB PD option.
Thoughts please?
Regards
Adam
BMS:https://www.amazon.co.uk/SODIAL-Lit...ds=4s+bms&qid=1552122125&s=electronics&sr=1-3
USB output:https://www.amazon.co.uk/gp/product...4d5-a0de44c50a7e&pf_rd_r=4X6KM694QZ1EV09VT0BA
Thoughts please?
Regards
Adam
