You're using breakers rated for AC220V only, not for DC. :exclamation: This is likely dangerous :exclamation: . DC will create an electric arc when disconnecting, and will melt/burn breakers not designed to extinguish this arc. I strongly recommend you change all breakers.
Note that DC breakers often have a +/- as well asIN(PV)/OUT(Charger) directions you have to follow.
