Aaron Paluzzi
- Dec 29, 2017
- 2
Hello all,
I had thought I had found a darn perfect inverter for my home solar array in the MPP solar hybrid product. I was aiming at about 5kw, but I'm in the US. I need a split phase inverter and MPP's products don't quite hit the mark. Perfect if I was in a 220v country, not so much here. :-/
Is there another product on the market that would work for us here in the US? As I stated I was aiming at doing a 8kw array install. I'm not opposed to splitting it across two inverters if needed (I was prepared to do this as MPP only has at max a 5kw inverter). With MPP struck out my only other inverter close to what I want is a StorEdge, and with that I can't use my 18650 packs. Is there anything out there or should I just sell off my 18650s and go with the StorEdge?
