Crimp Daddy
- Feb 21, 2018
- 973
Local pickup only in Southern CA - Los Angeles area
Each module is 5s configuration. They would be best used with 3 in series for a 15s configuration. The "48 volt"voltage range is fully supported by many manufactures, including Victron Energy. Their inverters and MPPT solar charge controllers caneasilyhandle 15s mix/max range.
Two in series (10s) is an ideal 36 voltconfigurationfor something like a golf cart. Single5s can be used in a 12v system when used with a DC-DCconverterto buck the voltage (Victron 24/12 Orion isolatedconverters will support this)
Capacity~ 1.1kWh per module
5sConfiguration
Output Terminal: M6 Nut
Cost is less than $100/kWh per module.
Group 1 ~ 12kWh $1200 for the lot, or $120 per module if separated.
Really good condition, includes folding terminal caps for all even thought it's not pictured. Removed from a lowmileageEV. I started workingon them but never finishedthe project.I spot checked a couple modules with my iCharger 4010 and both measured at full capacity.
Group 2 ~ 9kWh /[size=small]UPDATE: 5 of 9 SOLD. $110 each (no +/- terminal caps)[/size]
Here is some more media and info about them.
5sConfiguration
