Hi,
I want to build mostly a UPS (for computers and some home appliance) solution with EVE 3,2V 280Ah cells (16 pieces, 48V) and MPP Solar inverter (parallel 2 inverter).
I looked on the MPP Solar PIP 5048 MK model (EU):
http://www.mppsolar.com/manual/PIP-MK%20%28PF1.0%29/PIP-MK%20manual-20190717.pdf
This is the only MPP inverter where it says:
Transfer Time:
Line mode+Battery mode: 0ms
Inverter+Bypass: 4ms
Anyone uses MK series inverter?
It is really like an online (double conversion) UPS where battery always works ?
How much is the energy loss because of this double conversion ?
The other question is about battery. It is always charging the battery? Or flooding it?
Batteries does not like to be charged after full, but because there is power needed in the load side ... so how does it do it?
Discharge 10% and the charge 10% ? Or constant charge ?
Lithium batteries will like it ?
Any info is appreciated
Thanks
Transfer Time:
Thanks
