LG LGABF1L1865 Cell Specifications
Brand:LG
Model:LGABF1L1865 (INR18650F1L)
Capacity:3350mAh Rated
Voltage:3.63V Nominal
Charging:4.20V Maximum
975mA Standard
1625mA Maximum
Discharging:2.50V Cutoff
650mA Standard
4875mA Maximum
Description:Purple (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://keeppower.com.ua/download/2015-11...F1L_v1.pdf
Pictures:
None. Please submit some!
Berniedorf likes this post
HIGH CAPACITY!! 3400mAh Panasonic 18650 Cells, Only $1.25/ea!
These LG cells are used in a 26,800mAh RAVPower USB-C 30W Power Delivery powerbank. It looks like they’re in a 2S 4P arrangement.
I tore this pack down for a couple of reasons:
- I wanted to see what kind of cells they use in these higher output powerbanks
- I would like to up-rate the pack to a higher capacity
This pack is available from Amazon (usually for about £55 in the U.K.) and was on offer for about £37 when I bought it.
I was curious what kind of cells they use in these packs as they can output up to 30W (either 15V 2A or 20V 1.5A at the higher end) using the USB-C Power Delivery spec.
The 26,800mAh rating works out to 3350mAh per cell, as per the data sheet. Although the real life capacity of the whole pack is probably less than this due to losses during voltage conversion.
Definitely not the cheapest way to get hold of cells, but certainly quick if you want guaranteed new genuine cells.
(05-10-2018, 07:37 AM)solar_18650 Wrote: These LG cells are used in a 26,800mAh RAVPower USB-C 30W Power Delivery powerbank. It looks like they’re in a 2S 4P arrangement.
I found nothing on the link you posted!
Is there another link to take me to the pack you mentioned ?
Sorry, I didn’t put a link in - the Amazon one was added automatically.
Here’s a link to the actual product:
https://www.amazon.co.uk/dp/B06XTMK9H2/
EDIT - opening this USB powerbank is a one way ticket. It was not easy to open or separate the casing, so don’t expect to put it back together after getting it apart! I had to tear the plastic using some large grips and it looked like it was glued in on the seams of the case work.
(05-10-2018, 08:55 AM)solar_18650 Wrote: Sorry, I didn’t put a link in - the Amazon one was added automatically.
Maybe for the Brits Smile
Thanks for the link and the instructions how to open the box but again "does not ship to SA" Angry
These cells are also used in the Xiaomi YDDYP01 20000mAh powerbank. 6 Cells parallel. Much cheaper atm.
Xiaomi 10000 mahpowerbank included 3 pcs. LG-LGABF1L1865
a very detailled tester in danmark tested this cell too: https://lygte-info.dk/review/batteries20...%20UK.html
i bought 2700 of them for my powerwall
the danish tests are very similar to what i tested
