  • 1 Vote(s) - 5 Average
LG LGABB41865 Cell Specifications
Brand:LG
Model:LGABB41865 (ICR18650B4)
Capacity:2600mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1250mA Standard
2500mA Maximum
Discharging:2.75V Cutoff
500mA Standard
5000mA Maximum
Description:Gray Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.batteryspace.com/prod-specs/5457_B4.pdf
Pictures:
I have a pink one of these. Is it helpful to add it to the cell database? Or is color not important?
(09-13-2017, 08:34 PM)David Pesce Wrote: I have a pink one of these. Is it helpful to add it to the cell database? Or is color not important?
Yes, please share pictures. I haven't decided what to do when the same cell has two different wraps. We'll probably end up creating a separate entry on the cell list since the idea is for identification.
hbpowerwall likes this post
Guys im 13 years old i got kinda the same batterys from coolpad big daddy idk why they called it that its 10000 mah full but the lower numbers are 0090c318a4 can somebody send me a link for specs or mah ?
No such thing as a 10000mAh 18650 cell. It's fake if "rated" at that. Unless you mean the pack is rated at that. Secondly, the bottom numbers are just for manufacturer location, date, etc. It has no real bearing on the cell itself. So if the top numbers are the same, then that's pretty much the cell.
Guilherme likes this post
I just pulled some of these out of a laptop battery pack.   LGABB4185.  Gray wrapper.  Came off the charger at 2564 mAh.  Wish I knew which model pack it came from, I sure hope to find more of them!  Charger used was an XTAR VC4.  Cell was first charged then drained to about 3.5 V (ebay usb powerbank shuts off), then charged again.
Just had to look it up and found these forums. So here's my first post! Smile
flashlights are an addiction
I pull 4 of these from an old pack the other day, their wrapper is brown with a white ring. Average capacity was 2,057 mAh between the 4 cells and varied by about 25 mA.
(08-10-2019, 03:43 AM)NicholasTesla Wrote: I pull 4 of these from an old pack the other day, their wrapper is brown with a white ring. Average capacity was 2,057 mAh between the 4 cells and varied by about 25 mA.
that's a LGABC41865 cell. different from the LGABB41865 cells listed here. nominal capacity 2750 mAh for the brown cell so if you only got around 2000 then that cell has been heavily abused.
raccoon likes this post
I have at least 16 of these in brown...   Is this correct?
