tin solder
What is your preferred solder?
I've bought 3 on aliexpress and two local.
All 5 had different characteristics.
What would be your coise?
Thanks in advance
I use Kester 24-6337-0027 Solder Roll, Core Size 66, 63/37 Alloy - https://www.amazon.com/gp/product/B07KWD...UTF8&psc=1
I don't need to prepare or flux or anything - just solder directly with 100w iron.   My oldest packs are 3yrs  and the solder has not corroded or caused any long term issues.
Use 60/40 rosin core based standard solder. I use 300W high perf soldering pen with heavy duty copper tip. It makes sure i only need 1 second to solder and nothing else.
100+watt is generally needed and a tip that have big mass. I dont buy tin on ébay like sites. Thats something i buy from proper vendors so i get proper stuff! Its such a difference.
You should never have to grind on the cells.
I have done videos showing how easy it should be to solder. Heat, tinn and then it flows directly.
Here's a good run down of solder types:
And flux
100kwh-hunter likes this post
