Notice To Unregistered Users: By visiting this forum, you are automatically agreeing to the terms and conditions set forth in our Safety Notice & User Agreement. All electrical work shall be completed by a qualified and licensed electrician. Admins, moderators, and members do not accept any liability for the information posted here. Please make sure to read the Safety Notice & User Agreement for the full disclosure. To remove this message, please register for an account.
Lux's Powerwall
Intro
With this topic i want to start my own powerwall/Solar shed.
Idea
These idea's can change any moment the more experince i get.
In my back yard stands a 2 by 2 meters shed the idea is that my projects will be all powerd by solar panels.
Until i get more solar panels i will have to do with one 40w panel (estimate).
The solar panel will charge my powerwall made from recyceld 18650 cells.
The powerwall will be feeding a couple of devices:
  1. A Raspberry pi B+ running boinc and a webserver for stats 3 watts.
  2. 2 Antminers 1,6ghash , 2 asic blockerupters 366 mhash total power 10 watt.
  3. Controll board 5 watt (estimate).
  4. Small water pump 5 watt.
Projects
All the individual projects that combine in one solar shed.
  1. Powerwall
  2. Controll panel
  3. Raspberry pi data logger
  4. Solar Bitcoins
    more projects will be added in the future
Powerwall
The powerwall will be build from 18650's.
The system will run on 24v so the pack will be 6s how many in parallel will be depending on the total amount of cells i can get.
Controll panel
I will be making a controll panel where everything comes together.
On the controll panel there will be a couple of volt and amp meters.
There will be a costum pcb with a solar controller.
Raspberry pi
The Arduino will measure everyrthing and sends his data to the rapsberry pi that host a web page where you can see al the data.
On the pi runs a boinc client to uses up all the unused clock cycles.
Solar Bitcoins
I have a couple usb bitcoin miners laying around that will be connected to the pi that runs the bitcoin client.
Yes i know i am not getting any reasonable amount of money but it is just for fun.
In a year i make 0,95 dollar cent or so.
End
Everytime there is someting new i will post a update.
bye for now: Lux
While your devices add up to only around 23 watts you have to remember that you might not always be getting a full 40watts of output from your panel and also you need to keep the system running through the night when there will be no solar so you need to be able to power the system and also store enough energy through the night. At a guess your not going to have enough power to be able to do that with the planned setup and would need more solar to make it operate 24/7.
I would also look to go 7s on the pack which fits in a little better with a 24 system.
Col
For this many loads, i highly doubt a 40Wp panel is enough. I bet you need at least twice as much. 100Wp panels are reasonabl priced. Much less cash per Watts than a 40Wp one-
Chickey Wrote:While your devices add up to only around 23 watts you have to remember that you might not always be getting a full 40watts of output from your panel and also you need to keep the system running through the night when there will be no solar so you need to be able to power the system and also store enough energy through the night. At a guess your not going to have enough power to be able to do that with the planned setup and would need more solar to make it operate 24/7.
Col
Hi Col
Thanks for your respons.
Your a totally right about that i will not have enough solar power for 24/7.
The 40 watt is a estimate i have not tested in the real world.
Again your a right with the 7s pack i made a miss calculation.
Shoopinguin Wrote:For this many loads, i highly doubt a 40Wp panel is enough. I bet you need at least twice as much. 100Wp panels are reasonabl priced. Much less cash per Watts than a 40Wp one-
Same as above it is a estimate i will be looking in a second solar panel.
The panel i have now was a gift.
Again Thanks for the comments.
Look forward for a update.
Bye for now Lux.
Update 01
Intro
My first batch of cells arived.
Next time i will take pictures with a good camera.
Photo's
[Image: WY2fbvX.jpg]
Opening the packs with a hammer and a screwdriver some people maybe scared of this, But if you do it correctly you dont damage the cells.
[Image: ktXt13V.jpg]
Sorting the cells by color
[Image: QFxFB0s.jpg]
Charging
For now i am charging the cells with 2 tp4056's,
It is slow but there are more chargers on there way.
List of what i will be ordering for the charging proces:
8x tp4056
2x 18650 x4 holder
Cell processing
the past week i have been strugeling about how i will be testing the cells.
What is the right order to test the cells:
Measure voltage cell -> charge the good cells -> discharge the cells -> write the mah data on the cells -> charge the cells.
or
Measure voltage cell -> charge the good cells -> write the voltage on the cells -> store the for a week-> Measure the voltage for selfdischarging-> discharge the good cells-> Write the mah on the cells-> charge the cells
What is the rigt way? Does some one else have a better way?
Dischargers
I want to discharge the cells with a diy discharger.
https://www.youtube.com/watch?v=WScPyfQz_f8
Reason why i dont want to discharge with a imax b6 of some sort is that you only can discharge one cell at the time and they are more expensive.
I want to build 4 dischargers, Best would be if there be one arduino with 1 display with a couple buttons to scroll trough the values.
With 4 resitors and 4 cell holders.
only problem is that i can not edit or program the code maybe there is someone on this forum who find this a interesting project, i think a lot of people find it helpfull.
Now i have to buy 4 arduino's 4 lcd's the arduino and the lcd are the most expensive.
Bye for now and good luck with your own powerwalls.
Lux
Loking forward to see all of this grow.
Nismo nick Wrote:Loking forward to see all of this grow.
Thnx for you reply.
The next update will be about extracting busbar form transformers.
Lux
Hi Lux,
I'm using an Opus BT- C3100 V2.2 Digital Intelligent 4 Slots LCD 10400 14500 Battery Charger, bought brand new off eBay for AU$50. Works great, just put your cells in the charger, select the mode and walk away.
John
Tesla101 Wrote:Hi Lux,
John
thanks for you reply,
i have read al lot about the bt-c3100 charger/discharger but it is to expensive for me at this moment.
Maybe i find one second hand.
Lux,
CrankyCoder likes this post
If you already have some 12v power supplies which have a 2.1mm barrel connector then you may want to consider the liitokala 4 cell charger/discharger which is very cheap, will be slightly lower tomorrow.
http://s.click.aliexpress.com/e/URjI6QJ
87 User(s) read this thread:
Redmohawk (05-07-2017, 11:56 AM), mitchvr (06-19-2017, 12:45 PM), Arie Bal (07-07-2017, 09:25 AM), Stefaan De Ridder (06-27-2017, 08:00 PM), systemtm (08-30-2017, 08:33 AM), Inverted 18650 (07-05-2017, 02:36 PM), roel.nagels@telenet.be (07-05-2017, 07:54 AM), pruesel (11-04-2017, 12:41 PM), al4sound (03-08-2018, 12:37 AM), kot (06-29-2017, 07:50 PM), Taz D'vil (07-08-2017, 01:44 AM), Tommy Ng (05-16-2017, 12:16 AM), John (05-09-2017, 05:51 AM), Christian (05-06-2017, 11:33 AM), Radi (05-30-2017, 10:17 AM), Off Grid Power wall (06-07-2017, 08:01 AM), Henderson (06-01-2017, 02:37 PM), Newidea (06-11-2017, 07:31 PM), krawcu (09-07-2017, 05:51 PM), ivnz (06-08-2018, 01:52 AM), notoriousbdg (11-19-2017, 06:11 PM), Charly144 (01-19-2018, 08:04 AM), ClardiPower (01-12-2018, 01:02 PM), matthew (12-29-2017, 01:59 AM), Herbie (03-27-2018, 01:52 PM), Taylor Zepeda (01-02-2018, 08:40 AM), costty (03-29-2018, 08:05 AM), Sergio Rodrigues (02-07-2018, 11:15 PM), DK100 (04-25-2018, 09:43 PM), pavlik1974 (05-06-2018, 11:42 PM), Ginger Yang (11-07-2017, 06:33 AM), Filip (12-17-2017, 05:52 PM), Kenneth Bonanno (12-04-2017, 02:04 AM), Ivo Staelens (09-17-2017, 08:40 AM), AlexCPU (09-22-2017, 01:15 PM), ps915 (09-04-2017, 10:04 PM), Pierre (10-06-2017, 03:29 PM), cristof (12-04-2017, 11:42 PM), Bryn (11-03-2017, 05:43 PM), hro413862 (12-02-2017, 07:23 AM), Oliman (04-08-2018, 08:10 AM), VicRC (05-11-2017, 11:28 PM), hbpowerwall (10-11-2017, 01:18 AM), JustJim (03-04-2017, 05:18 PM), Korishan (08-15-2017, 03:13 AM), P.Tasyo Powerwall (03-10-2017, 11:15 AM), PAF (05-10-2017, 03:52 PM), FERCSA (05-06-2017, 09:04 PM), Prahe86 (04-19-2017, 07:24 PM), theDIYHobbyist (02-11-2017, 04:08 AM), ruby2 (05-04-2017, 04:37 AM), Herebus (03-28-2017, 07:35 AM), daromer (05-03-2017, 05:40 PM), mike (05-31-2017, 07:39 PM), goodnowm (10-14-2017, 06:46 PM), NiVa (06-01-2017, 12:03 AM), Lux_Gamer (01-07-2018, 04:46 PM), opus40 (04-09-2017, 02:21 AM), VdVoort4 (05-31-2017, 06:51 AM), Majorphill (05-05-2017, 11:25 AM), riveracc1 (08-19-2017, 06:21 AM), coolfx (05-29-2017, 05:50 AM), Franky Beuselinck (02-12-2017, 07:53 PM), steve (02-17-2017, 11:40 AM), crud (05-03-2017, 06:47 PM), Zagy (05-04-2017, 06:02 AM), 2146 (05-04-2017, 04:19 PM), wim (08-18-2017, 11:13 AM), hugo5464 (04-11-2017, 05:02 PM), wimpie007 (05-12-2017, 12:47 PM), coconut2k13 (05-06-2017, 09:24 PM), MajStealth (05-03-2017, 06:22 PM), frnandu (05-04-2017, 09:57 PM), melsom (05-14-2017, 05:16 PM), camils (05-04-2017, 04:04 AM), charlie246 (05-04-2017, 09:15 PM), Wattsup (05-04-2017, 11:54 AM), Project (02-25-2017, 03:10 AM), Tristan Timmer (02-25-2017, 11:58 PM), memloc (03-27-2017, 11:36 AM), oni (03-24-2017, 10:06 AM), CrankyCoder (03-27-2017, 07:04 PM), Alec_J (05-06-2017, 01:36 AM), flight4900 (05-03-2017, 08:38 PM), C11MAN (05-04-2017, 05:37 PM), jdeadman (05-03-2017, 07:29 PM), typ49 (05-16-2017, 07:03 PM)
