Notice To Unregistered Users: By visiting this forum, you are automatically agreeing to the terms and conditions set forth in our Safety Notice & User Agreement. All electrical work shall be completed by a qualified and licensed electrician. Admins, moderators, and members do not accept any liability for the information posted here. Please make sure to read the Safety Notice & User Agreement for the full disclosure. To remove this message, please register for an account.
IFR 26650 Powerbank
A productive weekend.
I found this form, introduced myself and managed to strip down 10 more power packs to harvest useable cells.
+/- 450 Cells and counting  Cool (all need to be cycled/charged)
introducing the powerpacks:
54,4V used in PPE equipment
34 cells A123 26650 in each pack
I dont have the BMS for these packs and the are 54,4 V.
I have a 12V system in my house so I will brake down these packs check the cells and make custom packs.
http://lygte-info.dk/review/batteries201...%20UK.html
How I harvest my Cells:
Starting with removing the soft heatsink check what the Voltage is if any good I start with stripping.
Cutting all the wires from the old BMS
I don't know how you guys remove spot welded strips.
I use a sharp chisel to lift a corner and peel them off with pliers while guiding the strip to prevent Sparks... Angel
same procedure on the other side.
Then the "fun part" taking all cells apart.
They are glued together so most of the heat shrink peals off. (I ordered new shrinks since the positive side is on the outside...)
Stripping them takes me 20 Min each for the standard ones.
Unfortunately I also found that a lot of packs are "dead" 0 Volts.
Also on the cells.
I'm not sure if I can "bring them back" So I stripped 2 down for testing later on.
For now I'm focused on stripping working packs that still give 50ish V.
These packs are replaced after 2 years of use or when they don't work any more.
I must have been lucky with the first packs because they where all good 50ish V
And all others are unknown...
I also have some sealed packs that are cracked they take over a hour to strip and they only have 17 cells..
But these are all from a new model from 2016, So all new cells Big Grin
Thats it for now. i'm waiting to get new heat shrink and plastic cell holders in.
I'm not sure about the pack size's I want to build.
First I will use the packs in my offgrid house and in my T3 camoperVan.
I'm also thinking about a EV conversion of my T3 campervan so I might want to create a pack with 12V i can use in house and place together 300ish Volt in the car..
hbpowerwall and BlueSwordM like this post
Greetz Dennis
http://www.verticallife.nl
Current Of-grit setup
5 230Wp canadian Solar panels
2 Voltmaster 270Ah 12V Battery's
1 Outback flexmax80
1 Phoenix 3000 inverter
On the moment I'm waiting to get some Opus chargers.
I tryout the Xstar VC2 plus master
http://lygte-info.dk/review/Review%20Cha...%20UK.html
to find out it's not supporting the cells I want to charge IFR 26650
What about the Opus charger do they support LiFePO4? 3,3 V
Greetz Dennis
1 Outback flexmax80
There is internal switch on the Opus. Not sure if it was for HiV or LiFe at 3.2V
They do not support 26650 very well. I know it says 26650 but the ones i have doesnt give any contact out from default
The review says that the button function was not tested, thats why it says maybe.
So there is only one way to find out.. lets see when the arrive here.
I order 8 of them now for 10 US each..
http://www.ebay.com/itm/New-EU-PLUG-Opus...SwrfVZOT~p
Greetz Dennis
1 Outback flexmax80
Maybe you should check that ebay listing for authenticity. The seller is in Shenzhen, China and the price is very, very cheap ( USD $9.99 inc shipping). Lowest price I can recall is around USD $30 from Aliexpress.
Yep, there were others who got burned by false sales. If the opus is less than $20, it starts to be questionable.
The other 3 bidders had to file for refunds with ebay.
Dollar Shave Club. Best Razor I've ever used
Thanks for the warning.
I ordered from 3 different suppliers for 10us..
I can always refund if they don't deliver . long I've PayPal Big Grin
Greetz Dennis
1 Outback flexmax80
I also bought an opus for 15 € from another seller. The part has never arrived and the seller was deleted from Ebay. For $ 10 it's a fake. I would cancel the purchase!!!
Tried two for 10-15$ too few months ago and had to ask Paypal for money back, they are a lot of scams with Opus chargers recently.
Yeah. Opus is between 30-35USD. All at or around 10 USD are fake.
100 User(s) read this thread:
hbpowerwall (10-27-2017, 01:21 AM), Chickey (07-13-2017, 07:03 AM), daromer (11-26-2017, 03:53 PM), mike (12-03-2017, 10:16 AM), goodnowm (01-03-2018, 04:24 AM), BigBen (10-03-2017, 12:51 PM), station240 (09-13-2017, 01:37 PM), NiVa (12-03-2017, 11:05 AM), Lux_Gamer (09-16-2017, 05:17 PM), owitte (08-10-2017, 07:06 AM), opus40 (08-02-2017, 06:34 AM), VdVoort4 (10-29-2017, 08:23 AM), Majorphill (07-14-2017, 04:44 AM), riveracc1 (08-20-2017, 03:17 AM), coolfx (08-28-2017, 11:54 AM), Herebus (08-02-2017, 02:17 AM), ruby2 (08-27-2017, 01:59 AM), JustJim (12-26-2017, 02:29 AM), Korishan (12-19-2017, 08:07 PM), A + A (12-19-2017, 08:42 PM), PAF (12-23-2017, 08:17 PM), Franky Beuselinck (10-18-2017, 07:45 PM), Wattsup (12-18-2017, 04:51 PM), Scepterr (07-22-2017, 09:03 PM), Tristan Timmer (08-03-2017, 03:00 AM), hellfire88no (10-17-2017, 01:17 PM), Frnandu Martiński (10-17-2017, 09:53 PM), egam (08-04-2017, 11:34 AM), Alec_J (08-13-2017, 05:43 PM), flight4900 (08-10-2017, 10:58 AM), Mike C (10-23-2017, 11:43 PM), Droid126 (08-03-2017, 02:16 PM), eAnic (12-11-2017, 03:24 PM), jdeadman (12-20-2017, 02:32 AM), charlie246 (11-26-2017, 07:48 PM), Zagy (10-24-2017, 08:51 AM), 2146 (11-27-2017, 03:45 PM), wim (12-19-2017, 07:42 PM), wimpie007 (12-19-2017, 07:43 PM), ericg (12-19-2017, 10:43 PM), frnandu (10-23-2017, 12:51 PM), melsom (07-23-2017, 08:02 PM), josearaujo10 (08-04-2017, 10:02 PM), typ49 (08-10-2017, 08:03 AM), KD0CAC (07-11-2017, 03:21 PM), The-J-Man (07-12-2017, 03:29 PM), Tommy Ng (08-23-2017, 01:47 AM), Jeremy Choy (08-04-2017, 07:18 PM), 1958 greyhound (08-26-2017, 08:18 PM), Abarth595 (08-07-2017, 07:29 PM), Quigibo27 (08-03-2017, 03:39 AM), kktuo (07-22-2017, 06:38 PM), neilmc (08-07-2017, 10:58 AM), Off Grid Power wall (09-12-2017, 10:10 AM), rebelrider.mike (01-15-2018, 11:53 AM), tbostjan (09-03-2017, 08:13 AM), kaits31 (09-07-2017, 10:14 AM), watts-on (12-20-2017, 09:14 AM), Dan Lim (10-23-2017, 07:14 AM), jesusangel (08-26-2017, 02:58 PM), arierep60 (10-04-2017, 02:23 PM), BamBamsBatteries (08-13-2017, 12:17 AM), Daggerzz (08-02-2017, 05:43 AM), alexcj (09-09-2017, 01:01 PM), Hanssing (12-20-2017, 06:42 AM), MetalFang (08-03-2017, 08:30 PM), Fredd (08-02-2017, 01:32 PM), IronSky (10-17-2017, 10:00 AM), Mark Daniel Olsen (12-18-2017, 03:07 PM), DrkHrs13 (07-23-2017, 02:11 PM), silverse2m6 (07-11-2017, 11:09 AM), kot (07-12-2017, 07:41 PM), Arie Bal (08-03-2017, 02:00 PM), ismaildoganw (08-02-2017, 06:08 PM), kazbach (12-20-2017, 06:55 PM), Larry Tipton (08-03-2017, 02:56 PM), ltdorn (08-07-2017, 02:15 AM), Davel (08-16-2017, 09:31 AM), Stefaan De Ridder (11-26-2017, 06:26 PM), JohnC (09-06-2017, 10:11 PM), TomTinkerDIY (07-11-2017, 07:58 PM), Chiptosser (11-26-2017, 04:30 PM), Chicken (11-20-2017, 04:30 PM), Power Up (07-15-2017, 07:13 AM), systemtm (08-04-2017, 06:00 PM), Inverted 18650 (08-04-2017, 05:57 PM), Lawcomleo (08-17-2017, 09:36 AM), BlueSwordM (08-26-2017, 07:45 PM), Piotr Dziel (08-23-2017, 05:26 PM), Johnny Stauersbøl (08-27-2017, 11:27 AM), Dennis Van Hoek (04-27-2018, 10:27 AM), alildabldo (07-14-2017, 02:26 AM), adr1an_id (07-10-2017, 06:48 AM), Happy Camper Homesteader (07-13-2017, 12:16 AM), brafi (08-12-2017, 09:24 PM), Stew Mohr (08-07-2017, 12:45 PM), Jesse Osborn (07-15-2017, 01:33 PM), Nitroghost (08-13-2017, 02:17 AM), John.Siler (08-03-2017, 12:20 PM), Jan Pieter van Zijst (08-27-2017, 11:34 AM)
