  • 7 Vote(s) - 5 Average
Glubux's Powerwall
#51
To replace a cell, you have to break the 4 plastic corners around a cell and unsolder the fuses. Quite easy.
#52
(12-29-2016, 07:16 PM)Glubux Wrote: To replace a cell, you have to break the 4 plastic corners around a cell and unsolder the fuses. Quite easy.
That's another reason I went with the solid copper wire bus bars, there is enough room to pull a single cell without having to unsolder the entire busbar like the previous design I used.
Glubux and shonalex like this post
#53
What is the rational behind keeping all the cells in a pack within 100 mAh of capacity?  Why not intermix and make capacity and cell number equal?
#54
You're right, there is not really a rational reason, I guess either way is fine, I just decided to go this way because manufacturers match their cells and also this design allows me to add cells if a pack is a bit weaker.
#55
I kinda figured that, but how do you keep the replacement cell in place. Remember I'm thinking about a mobile installation. Any ideas?
#56
That's a good question, on my first packs (page 1) the bus bar was directly soldered on the cell so it should stay in place, but with the second design, with only a .25mm fuse on each side, I think the best solution might be a gluespot.
FrostyDog likes this post
#57
You could look at cradles, similar to what I have done, but with inline ANL fuses for extra safety.
I can pop a cell in about 2 seconds, and insert in half that time.
Sorry Glubux, didnt mean to hijack!
#58
Thumbs Up
Nice idea mate, but I'm dealing with volume constraints, why I went for the 4X5 spacers. Also, I'm not sure how the cradles would hold up to the vibrations of an offroad environment. Thanks for the thought tho Smile
#59
Perhaps not the most interesting update but here is the new shelter for my system
Learjet, Elwood, miu And 1 others like this post
#60
Nice shed, is it far from the house/solar ?
