Hi folks,
unexpectedly I've got some laptop barreties with prismatic cells. First I wanted abondon this offer but later on I thougth I will give them a try.
It was a really hard work to pull them out of housing - it has to be done very carefully, not to bend them, not to press, not to destroy, etc . I've managed it.
The cells are from ATL. The measured capacity is in average about 1500 mAh.
The last time there are more and more prismatic cells around from flat laptops, tablets and other electronics and so I thougth we shall talk about them...
Then I started co connect them in parallel and after in serial to get a source of 24V.
Let's see waht will happen. The project is still under construction ;-)
I will be back later on...
BigBen
BigBen
