Sony US18650S STG Cell Specifications
Brand:Sony
Model:US18650S
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Blue Cell Wrapper
Beige Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
I believe these Sony cells to be 1500 mAh. I have just harvested 8 of them from a 14.8V 3000mAh pack, which indicates 3.6V x 4 and two in parallel to make 3000mAh total.
Everythings-stuck-together likes this post
I found this thread which says 1300-1400. Fits with the battery I pulled them from, which was a 14.8V 2500mAH (4s2p) pack: https://www.rcgroups.com/forums/showthre...nformation
I harvested 12 of these recently from used laptop battery packs, 8 capacity tested in the 1100-1199 range and 4 capacity tested in the 1000-1099 range. As a used cell I would say these #s are in line with what you guys stated as the likely Original Capacity.
(10-26-2017, 08:51 PM)Aaron Cocker Wrote: I believe these Sony cells to be 1500 mAh. I have just harvested 8 of them from a 14.8V 3000mAh pack, which indicates 3.6V x 4 and two in parallel to make 3000mAh total.
I can confirm they should be 1500mAh cells as have just removed the same cell from Dell with label attached
4s2p pack
cheers
Brett
Hello!
I have cells marked as US 18650S but the liner is green with black insulator ring.
Harvested 100 from old industrial scanners
Tests showed capacity from 1190 to 1394 mAh
If I find a way to attach a jpg I will post it here
