YikLik (YLE) INR18650A220 Cell Specifications
Brand:YikLik (YLE)
Model:INR18650A220
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
4400mA Standard
2200mA Maximum
Discharging:3.00V Cutoff
440mA Standard
2200mA Maximum
Description:Red Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
http://www.mountainprophet.de/wp-content...50A220.pdf
Pictures:
I don't mean to be a detail nazi, but are you sure you've got the discharge current and charge current right? Shouldn't those be in A or mA?
By the way, I've only just stumbled upon this whole section for cell specs on the forum. Looks like a huge amount of work. Thank you!
-Mike G
(07-19-2017, 02:34 PM)rebelrider.mike Wrote: I don't mean to be a detail nazi, but are you sure you've got the discharge current and charge current right? Shouldn't those be in A or mA?
You are not being a detail nazi, you're absolutely correct. I fixed the template and regenerated all posts. Thank you Smile
Just got that first cells.
Is there anybody got the datasheet. The link seems broken.
Thanks
EDIT : link is up again
mike likes this post
(09-20-2017, 09:22 PM)Tostaki Wrote: Just got that first cells.
Thanks
I was just going to say it was working for me then saw your edit Smile
I have the same number on some cells , but with a white insulator ring instead with a black ring
Wrap, print and number are exactly the same.
Mine tested all above 2400mah, came from some laptop battery's
Best
i ve got them(White ring)should be the new cosmetic YLE red
A little late to the party but.. lol I just opened some with black rings in a battery pack was out of a Rayvac so the black is older than the white?
AWESOME SITE BTW !!! Thank you so much for making this site it has been so helpful!
(04-27-2019, 04:28 PM)100kwh-hunter Wrote: I have the same number on some cells , but with a white insulator ring instead with a black ring
It seems that they come with white rings too:
Quote:Charging:
4.20V Maximum
4400mA Standard
I think 440mA standard Wink
P.S. why not add current ratings equivalents in C-rating like 440mA/0.2C?
