YikLik (YLE) INR18650A220 Cell Specifications
Brand:YikLik (YLE)
Model:INR18650A220
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
4400mA Standard
2200mA Maximum
Discharging:3.00V Cutoff
440mA Standard
2200mA Maximum
Description:Red Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
http://www.mountainprophet.de/wp-content...50A220.pdf
Pictures:
I don't mean to be a detail nazi, but are you sure you've got the discharge current and charge current right? Shouldn't those be in A or mA?
By the way, I've only just stumbled upon this whole section for cell specs on the forum. Looks like a huge amount of work. Thank you!
-Mike G
(07-19-2017, 02:34 PM)rebelrider.mike Wrote: I don't mean to be a detail nazi, but are you sure you've got the discharge current and charge current right? Shouldn't those be in A or mA?
You are not being a detail nazi, you're absolutely correct. I fixed the template and regenerated all posts. Thank you Smile
Just got that first cells.
Is there anybody got the datasheet. The link seems broken.
Thanks
EDIT : link is up again
mike likes this post
(09-20-2017, 09:22 PM)Tostaki Wrote: Just got that first cells.
Thanks
I was just going to say it was working for me then saw your edit Smile
I have the same number on some cells , but with a white insulator ring instead with a black ring
Wrap, print and number are exactly the same.
Mine tested all above 2400mah, came from some laptop battery's
Best
Still learning English. Learning Li ion and solar technology.
4200 cells in packs Exclamation above 2500mah and 90%soh.
1500 waiting for testing.
Saving for 3 times phoenix inverter 48/3000 230v to gain also 380v
3 chargers?
Time is our enemy, must work to, the sun is our friend, must relax to.
With best regards
i ve got them(White ring)should be the new cosmetic YLE red
Building Lifepo4 Powerwall - atm 1400 cells growing
A little late to the party but.. lol I just opened some with black rings in a battery pack was out of a Rayvac so the black is older than the white?
AWESOME SITE BTW !!! Thank you so much for making this site it has been so helpful!
(04-27-2019, 04:28 PM)100kwh-hunter Wrote: I have the same number on some cells , but with a white insulator ring instead with a black ring
It seems that they come with white rings too:
Quote:Charging:
4.20V Maximum
4400mA Standard
I think 440mA standard Wink
P.S. why not add current ratings equivalents in C-rating like 440mA/0.2C?
LiFePO4: QB26650 2500mAh 50A vs A123 ANR26650M1B: https://youtu.be/GOSkte11lRc
Yinlong LTO Lithium Titanate safety tests: https://youtu.be/eAUYbSDEy6I
Toshiba SCiB LTO Lithium Titanate safety tests: https://youtu.be/XsrRDZxEFQE
XTAR DRAGON 4-slot battery tester review: https://youtu.be/S6yVMsIuauE
Miboxer C4-12 4 slot x 3.0A charger review: https://youtu.be/X-ww1YALjvU
Miboxer C2-4000 smart battery tester review: https://youtu.be/jrbJceNXv1g
Samsung 33J for TESLA: https://youtu.be/7FMxgMmPeh4
Samsung 40T - a high drain 35A 21700 cellhttps://youtu.be/lxgKWiQ9580
100 User(s) read this thread:
daromer (07-19-2017, 02:40 PM), mike (12-05-2018, 05:57 PM), Majorphill (07-20-2017, 01:24 AM), riveracc1 (11-11-2018, 05:39 AM), gulik154 (12-07-2017, 10:02 PM), CUDAcores89 (05-30-2018, 04:04 PM), Korishan (09-21-2017, 12:21 AM), A + A (09-21-2017, 11:58 AM), PAF (06-23-2019, 08:33 AM), Batrium (07-20-2017, 06:07 PM), Wattsup (07-22-2017, 09:56 AM), jdeadman (05-07-2019, 01:55 AM), wim (09-21-2017, 04:43 AM), Joe Farrugia (12-19-2017, 08:26 AM), frnandu (09-24-2017, 06:29 AM), HandyAndy (03-10-2018, 03:10 PM), neilmc (07-20-2017, 01:43 AM), Kaspars Krumins (03-29-2018, 12:52 PM), rebelrider.mike (07-09-2019, 10:15 PM), watts-on (06-25-2019, 08:36 AM), jesusangel (07-19-2017, 06:47 PM), Hanssing (07-19-2017, 02:43 PM), michael40324 (07-21-2017, 02:13 PM), Mark Lex (02-09-2019, 02:36 AM), Stefaan De Ridder (05-07-2019, 11:05 AM), Steven Melhuish (10-09-2017, 03:52 AM), Mario (10-09-2017, 07:52 PM), Chris Evans (08-19-2017, 10:30 PM), BlueSwordM (07-20-2017, 04:14 AM), SolarWind (09-24-2017, 01:10 PM), Bill Nye (09-09-2017, 03:48 AM), Erik Smith (09-07-2017, 04:37 PM), Terry (09-05-2017, 10:46 AM), N00bPwr (09-16-2017, 07:58 PM), Marcin Janiak (07-30-2017, 12:41 PM), VEmpire (09-25-2017, 03:31 PM), Geek (06-24-2019, 01:51 AM), TAGG (09-22-2017, 09:15 AM), Longbush Powerwall (11-25-2017, 11:38 PM), SWEwall (09-27-2017, 05:06 PM), Jon (10-03-2017, 03:31 AM), jose215 (11-11-2017, 04:16 AM), Mrsmith (09-12-2017, 02:55 AM), Olberg (11-17-2017, 11:46 AM), floydR (10-21-2017, 12:18 AM), SimonW (09-21-2017, 04:14 AM), Azuria (09-19-2019, 07:11 AM), abhijithym (09-14-2017, 03:32 PM), hookemdevils22 (03-22-2018, 07:01 PM), NaoDarkness (05-28-2018, 08:06 PM), grgdgreek (02-20-2018, 03:51 PM), zombielinux (09-04-2017, 09:18 PM), Peter Kay (10-22-2017, 03:44 AM), DarkRaven (09-21-2017, 12:08 AM), Grumplestiltskin (07-30-2018, 06:44 AM), SemaJG (12-05-2017, 02:08 PM), CaptFullbird (10-20-2017, 03:36 PM), Lucian Macota (09-21-2017, 09:47 PM), BernieS (10-28-2017, 03:37 PM), priba83 (09-16-2017, 06:54 PM), emerca (03-17-2018, 06:12 AM), Jeffrey Martin Smith (10-10-2017, 09:44 PM), ChrisD5710 (04-01-2019, 09:13 AM), Matthew Oliver (09-23-2017, 12:23 AM), Tostaki (11-15-2017, 03:35 PM), BatMan (09-30-2017, 02:18 AM), Mario Dinis (11-08-2017, 02:25 PM), badjaw (07-07-2018, 12:23 PM), howiegrapek (11-27-2017, 09:13 PM), cristof (10-17-2017, 02:44 PM), accoelho (10-05-2017, 10:39 AM), rev0 (03-04-2019, 10:06 PM), teccs (10-31-2017, 02:28 AM), xXxOlivierxXx (12-08-2017, 06:54 PM), silangovan14 (10-21-2017, 12:10 AM), lane5625 (12-21-2017, 08:40 PM), paz45 (11-14-2017, 11:22 AM), Everythings-stuck-together (11-05-2017, 11:01 AM), Ayenisoft (10-27-2017, 06:21 PM), Guilherme Souza Souza (10-29-2017, 03:16 AM), fabmec (11-19-2017, 12:26 AM), vlmendezjr (11-06-2017, 10:52 PM), Filip (12-16-2017, 11:21 AM), lula (12-11-2017, 02:01 PM), Inz (11-11-2017, 06:37 PM), putter32 (01-13-2018, 10:31 AM), probigor (11-19-2017, 04:30 PM), Oxygen (12-06-2017, 08:01 AM), benjemar1 (12-06-2017, 09:40 PM), Charly144 (06-23-2019, 05:52 PM), maunz (12-06-2017, 05:30 PM), nuno cesar (12-07-2017, 05:36 PM), plateau (12-02-2017, 01:48 AM), ClardiPower (03-13-2018, 06:47 PM), Louis Vandendriessche (12-19-2017, 12:29 PM), tipodoit (12-07-2017, 02:59 PM), alim (12-07-2017, 02:12 AM), lilijason6 (02-01-2018, 05:40 AM), ozewaste (07-21-2018, 01:59 PM), acidice333 (04-09-2018, 03:13 AM)
