Sony US18650GS Cell Specifications
Brand:Sony
Model:US18650GS
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
None. Please submit some!
Supposedly 2200mAh according to https://docs.google.com/spreadsheets/d/1...edit#gid=0
2250mah
Merk Sony
EAN/GTIN 0730484115692
Formaat batterij 18650
Chemie batterij Li-ion
Batterij Oplaadbaar
Nominale spanning 3.6 / 3.7V
Min. capaciteit in mAh 2.250,00
Uitvoering batterij Flat top
Ontlaadstroom 10,00
Protectie circuit Zonder
Hoogte in mm 64,50
Diameter in mm 18,00
NAVIGATIE
I found 45 of them, they all are tested above 2200, ambient temp 21 degrees celsius.
I found this data at a dutch commercial site, apparently 2250
Got a average between 90 to 100m ohm per cell???
Tested with a yr1035 kelvin
Found these in a TOSHIBA laptop battery, 3S2P as usual, nominal 4200mAh, so according to TOSHIBA these cells are 2100mAh.
