Sony US18650V2 Cell Specifications
Brand:Sony
Model:US18650V2
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
None. Please submit some!
SONY V2 SPECIFICATIONS TABLE
BASIC Brand Sony
Model name(s) US18650V2
Manufacturer full ソニーエナジー・デバイス (Sony Energy Devices)
Country of Manufacture Japan
UL number MH12566
SIZE Weight 46.00 g
Diameter, max. 18.20 mm
Height, max. 65.00 mm
VOLTAGE Voltage, charge max. 4.20 V
Voltage, nominal 3.60 V
CAPACITY Capacity, max. 2100.00 mAh
CURRENT Max. continuous discharge current 10.00 A
Peak discharge theoretic, 4 sec 17.5 A
C-rate (discharge, max.) 4.76 C
POWER Watts (discharge, max.) 36 W
ENERGY Energy, max. 7.56 Wh
Density volumetric theoretic 447 Wh/L
Density gravimetric theoretic 164.00 Wh/kg
E-rate (discharge, max.) 4.76 E
TEMPERATURE Temp discharge, min -20.00 °C
Temp discharge, max 60.00 °C
