Sony US18650VT3 Cell Specifications
Brand:Sony
Model:US18650VT3
Capacity:1500mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1500mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
300mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
http://www.avacom.cz/Datasheety/Sony/US18650VTC3.pdf
Pictures:
The datasheet seems to suggest that this cell can deliver 10A. I'm actually curious about this. I may test it with a 5a load and see if it gets hot. I intend to use it in a Vape device.
