Sanyo NCR18650GA Cell Specifications
Brand:Sanyo
Model:NCR18650GA
Capacity:3300mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1475mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
2000mA Standard
10000mA Maximum
Description:Red Cell Wrapper
Blue Insulator Ring
18650 Form Factor
Data References:
https://cdn.shopify.com/s/files/1/0674/3...2025043155
Pictures:
Full datasheet here: https://www.hurt.com.pl/prods/bat/_li_io...8650ga.pdf
Max charging current is 3.35A
