Sanyo UR18650RX Cell Specifications
Brand:Sanyo
Model:UR18650RX
Capacity:1950mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1360mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
390mA Standard
20000mA Maximum
Description:Red Cell Wrapper
Blue Insulator Ring
18650 Form Factor
Data References:
https://www.akkuparts24.de/mediafiles//D...8650RX.pdf
https://cdn.shopify.com/s/files/1/0674/3...RX.pdf?829
Pictures:
In section 10-1(1), it reads "Regarding UR18650RX, the charging current should not exceed 3.9A/cell.", so you can update maximum charge current to 3900mA.
