Sanyo UR18650SA Cell Specifications
Brand:Sanyo
Model:UR18650SA
Capacity:1200mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
840mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
240mA Standard
10000mA Maximum
Description:Red Cell Wrapper
Brown Insulator Ring
18650 Form Factor
Data References:
www.meircell.co.il/files/Sanyo%20UR18650SA.pdf
https://cdn.shopify.com/s/files/1/0674/3...SA.pdf?832
Pictures:
