Unknown ICR18650-23A-HENV Cell Specifications
Brand:Unknown
Model:ICR18650-23A-HENV
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Turquoise Cell Wrapper
Translucent Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
I have opened a pack with 6 similar marked cells, well almost:
Marking:  ICR18650-23A-APOKIN    CMICR18650F5-5DA
These has a white top ring.
Further info, Battery pack is marked: Replace PA3399U-1BAS  10.8 V 4400 mAh
PCB is marked APK-TS3399Y-BQ3060   V/A1 D20100813
I think this is genuine 2300 mAh cells sold as OEM or as secondary stock, read a little less capacity.
I will add the capacities I find later.
ChrisD
Tongue  Cells has now been tested and they look Great  Big Grin
Tested @ 1 Amp discharge: 2230, 2324, 2326, 2328, 2409 and 2418 mAh
ChrisD
Wink
From what i can tell they are a Samsung, 2300mAh battery
Are those different since the last set of characters is different? Or should we assume that's a serial number or something that's not part of the model number?
Looks like the trailing characters are actually part of the model number. Just tested a pack of 9 cells. Same model as your original posting.
(10-27-2019, 03:00 AM)cowpen Wrote: Looks like the trailing characters are actually part of the model number. Just tested a pack of 9 cells. Same model as your original posting.
I just havested a lot of cells (680 pieces of them) , which have the same model number, but other color.
by my opinion and after some resaerch, I think the "CM"  stands for the chinese compan "CHAM".
They have copied the oiginal ICR and sold them with their "CM" in front.
I found them in the powerpack of a e-scooter, imported from China to Germany.
They have 2200mAh nominal.
