  • 1 Vote(s) - 4 Average
Project Daft Idea
Ok, finally fleshed it out to a point where i am happy with it. and leaves the main host processor having to only worry about reading the 4 voltages per board, and kicking out some bits to a shift register, now this can be improved upon, and if you dont care about 3.175A charge / discharge, then some parts get cheaper, most notably the mosfets, and the through hole resistor. The temp sensors are not on the schematic, but it would be a case of placing one on the board very close to the N channel mosfets, and one against the battery,
per board, all in american $, prices from digikey, and this is single unit pricing, if your making a batch of them, that price drops a fair amount.
Total $12.01
IC's: $2.68
1x MCP6004 63c
1x MCP6001 35c
1x NX3L2467 98c
2x MCP9701 36c
Diodes: $1.16
4x CUS520,H3F 280mV Schottky diode $1.16
Mosfets: $3.28
2x Vishay Siliconix SI2365EDS P Channel $1.08 (they only act as a switch, so can be low power)
2x Fairchild/ON Semiconductor FDD306P N Channel $2.20 (i planned this around someone trying to charge / discharge at 3.175A into a 3.2V cell, this means about 3.5W dissipated in the mosfet)
Resistors 1% 0805 $1.89
2x 10R = 28c
14x 10K = 36.4c
21x 33K  = 54.6c
3x 68K = 42c
2x 1M = 28c
Resisitor 1% Through hole 5W $3.06
2x 0.2R = $3.064
Interesting. I'm not an expert at reading electrical schematics, but I am getting better. But I am still a lil over-loaded with it all.
Now, is this just the slave for each cell, or does this include the master as well? I'm thinking just the slave portion. $10/slave is kinda steep    Confused
What's with all the resistors on the Q1-Q7? How come you have 2 PMOS in the upper right? Just reversed to make the connection.
Ok, so yes it is per slave, if i drop the charge / discharge to 1A, things get a fair bit cheaper,
No master, really you can use any micro you want to control it, all you need is ADC's on the master to read, and 4 pins for setting the mode and dac.
The resistor ladder makes a R2R DAC, it comes out cheaper than any other kind of dac i can find, and is less effected by component tolerance, as all resistors would be from the same batch it would likely be a fair bit better than 1%,
The 2 pmos up the top are acting as a switch, if your discharging a cell, you don't want it still connected, otherwise issues will arrive, and the back to back configuration means the body diodes will not conduct if you put a cell in backwards.
dropped to 1A, i would expect about $4 cheaper, go up to 20 slaves and i would expect another 15% cheaper., equally using 0402 resistors you drop a full dollar.
you can do it cheaper by pwm'ing a resistor, i was just thinking along the lines of very little software overhead, the master can be absent 99% of the time, and no problems should occur,
93 User(s) read this thread:
hbpowerwall (07-25-2017, 11:17 PM), Brian Lawrence (02-26-2017, 09:14 PM), daromer (02-26-2017, 09:49 AM), goodnowm (10-24-2017, 06:27 AM), station240 (03-06-2017, 01:30 AM), PaulKennett (02-26-2017, 08:58 AM), NiVa (04-27-2017, 10:12 AM), Lux_Gamer (03-26-2017, 01:03 PM), Andreas Kvernes (04-29-2017, 09:00 PM), opus40 (04-09-2017, 02:15 AM), miwall (08-27-2017, 11:48 PM), VdVoort4 (04-21-2017, 11:03 AM), Grazor (12-06-2017, 01:55 PM), yenzand (09-09-2019, 08:51 AM), oscarjames (03-01-2017, 07:17 AM), Majorphill (02-26-2017, 01:53 PM), Nathan (03-07-2017, 12:56 AM), riveracc1 (08-10-2017, 08:42 AM), coolfx (03-04-2017, 05:30 PM), Herebus (04-03-2017, 07:56 AM), Rerouter (02-26-2017, 09:25 AM), smorgon (03-13-2017, 08:44 PM), BatteryDIY (09-07-2017, 11:10 PM), DanielD (03-08-2017, 12:04 PM), JustJim (02-26-2017, 03:31 AM), Korishan (08-15-2017, 03:14 AM), PAF (02-27-2017, 07:32 PM), Bob Muster (02-26-2017, 04:36 AM), Darmok (03-07-2017, 11:35 AM), Wattsup (04-24-2017, 08:54 AM), Elmo (02-26-2017, 12:16 PM), Project (03-05-2017, 03:40 AM), Batteriapan (02-26-2017, 11:10 PM), ozz93666 (02-26-2017, 05:11 AM), BobinTN (02-27-2017, 04:04 AM), Tristan Timmer (02-27-2017, 11:13 AM), Felineman (03-11-2017, 01:29 AM), oni (03-24-2017, 10:00 AM), egam (03-26-2017, 03:14 AM), Droid126 (03-28-2017, 06:19 PM), HogensHero (03-22-2017, 04:07 AM), charlie246 (04-02-2017, 03:39 AM), Rhys Browne (04-27-2017, 10:47 AM), Zagy (04-10-2017, 04:19 PM), wim (08-21-2017, 12:02 PM), hugo5464 (04-13-2017, 07:12 PM), wimpie007 (04-09-2017, 06:24 PM), frnandu (04-20-2017, 12:22 AM), melsom (05-21-2017, 02:27 AM), typ49 (05-20-2017, 08:56 PM), Tommy Ng (05-05-2017, 02:17 AM), Newidea (06-12-2017, 02:40 PM), DrkHrs13 (06-25-2017, 01:11 PM), kot (06-19-2017, 10:13 PM), mitchvr (06-19-2017, 12:57 PM), tremors (02-13-2018, 01:54 AM), Happy Camper Homesteader (07-18-2017, 10:52 PM), ivnz (08-13-2017, 07:02 AM), iofosho (10-27-2017, 01:03 PM), Morgan Jones (08-19-2017, 02:06 AM), CopyCat (08-23-2017, 04:59 AM), jamesk9 (08-24-2017, 05:37 PM), -=sT3V3=- (12-14-2017, 12:26 PM), ryaner (09-02-2017, 02:28 PM), Rahtid27 (09-08-2017, 10:26 PM), NicZa (09-12-2017, 09:44 AM), Han Mohr (01-01-2018, 07:53 PM), howiegrapek (12-19-2017, 02:22 AM), Jason.T.Keenan (09-28-2017, 12:31 AM), Panda (10-14-2017, 07:53 PM), Solexx X (03-20-2018, 09:24 PM), power65 (11-30-2017, 11:25 AM), sanglin (12-02-2017, 11:01 PM), tipodoit (12-07-2017, 05:00 PM), Jason Morris (12-27-2017, 11:27 PM), drchips (01-13-2018, 06:57 PM), Farends (02-18-2018, 09:10 PM), kanchana (02-27-2018, 05:01 PM), deGrootElectronicsRecycling (05-09-2019, 06:35 PM), DK100 (04-27-2018, 09:21 AM), Alex Pan Sakhnowski (04-30-2018, 03:35 PM), bukvaahmed@gmail.com (11-11-2018, 06:49 PM), PouakaiNz (07-11-2018, 08:54 AM), Powermad00 (08-08-2018, 04:20 PM), PaulDane (11-27-2018, 02:57 PM), veter (11-07-2018, 10:20 PM), dylancch (11-27-2018, 01:35 AM), barns (07-21-2019, 05:33 PM), Thatbakerguy (01-15-2019, 04:04 PM), GeneralDJ (03-11-2019, 12:56 PM), stok (07-18-2019, 09:20 AM), jiggyjonboat (08-04-2019, 02:42 PM), JennyRodds (08-27-2019, 11:34 PM)
