Beginners Guide to Processing 18650 Cells | Cell Database
  • 1 Vote(s) - 4 Average
Sanyo UR18650A Cell Specifications
Brand:Sanyo
Model:UR18650A
Capacity:2100mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1510mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
420mA Standard
6300mA Maximum
Description:Red Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://industrial.panasonic.com/cdbs/www...0CE285.pdf
Pictures:
The unknown Sanyo/Panasonic cell in the database with the (darker) purple ring may be the same model as this one. I've got a few red with purple here with "UR18650A R1112" very faintly embossed into the wrap lengthwise.
Ring variant for that cell
(10-09-2017, 07:22 AM)tin Wrote: The unknown Sanyo/Panasonic cell in the database with the (darker) purple ring may be the same model as this one. I've got a few red with purple here with "UR18650A R1112" very faintly embossed into the wrap lengthwise.
I can confirm, have some purple ones that have the UR18650A embossed as well.
https://www.tme.eu/en/Document/5057fe98d...18650A.pdf seems to be the proper datasheet from sanyo.
I also have a bunch of these cells with purple rings and "R1112" on some and "M32A" on others engraved texts.
Attaching images.
That said, I believe these cells should include all three rings colors on the cell database page.
(02-14-2018, 02:11 PM)thanar Wrote: I also have a bunch of these cells with purple rings and "R1112" and "M32A" extra engraved texts.
Attaching images.
The R1112 is thought to be a legal marking by Sanyo in Korea, the M32A is a date code.
J = 2005
K = 2006
L = 2007
M = 2008
32 = 32nd week of the year
A = revision
So looks like that cell was made in August 2008...
I have had fairly bad luck with the purple rings, they tend to heat up considerably at the final CV charge phase of the test sequence.
(02-14-2018, 04:41 PM)Detritalgeo Wrote: The R1112 is thought to be a legal marking by Sanyo in Korea, the M32A is a date code.
Fair enought on the R1112/M32A markings, however on my cells the "M32A" text is placed exactly where the "R1112" is on the other cells, as shown on photos.
I also have to agree on the recoverability of the "R1112" cells, I have none that even cleared 1000mAh. However, I've had quite some luck with the "M32A"s, got quite a few above 2000!
100 User(s) read this thread:
hbpowerwall (11-24-2017, 08:05 AM), mike (02-14-2018, 06:42 PM), owitte (08-03-2017, 03:24 PM), Majorphill (10-18-2017, 12:58 AM), riveracc1 (12-28-2017, 01:26 AM), Korishan (02-14-2018, 06:07 PM), brettwatty (11-16-2017, 07:06 PM), eeesOap (10-08-2017, 10:24 AM), wimpie007 (12-24-2017, 03:54 PM), Joe Farrugia (12-19-2017, 08:35 AM), frnandu (10-09-2017, 10:16 PM), Christian (10-25-2017, 06:39 PM), Jeremy Choy (08-27-2017, 05:07 AM), Robert Hauss (11-10-2017, 05:33 PM), rebelrider.mike (02-19-2018, 02:36 PM), worldlookingin (07-19-2017, 02:44 PM), watts-on (02-15-2018, 10:09 AM), Dan Lim (08-05-2017, 12:56 AM), João Luis Martins (11-08-2017, 08:36 PM), fcbrand (09-24-2017, 09:41 PM), bfleury (01-19-2018, 04:04 AM), quake101 (01-24-2018, 01:29 AM), ismaildoganw (07-25-2017, 10:24 AM), Mark Lex (11-16-2017, 05:50 AM), Stefaan De Ridder (12-06-2017, 06:29 PM), Hefferoni (10-03-2017, 02:50 AM), tremors (10-29-2017, 05:22 PM), John.Siler (07-19-2017, 01:04 PM), lewis3180 (07-29-2017, 10:54 PM), Erik Smith (09-01-2017, 08:40 PM), Terry (09-09-2017, 07:09 AM), N00bPwr (09-16-2017, 07:57 PM), Eric Koshinsky (11-15-2017, 01:02 AM), Marcin Janiak (09-30-2017, 08:22 PM), John Bender (11-20-2017, 12:48 AM), KaminoReal (02-17-2018, 05:38 PM), Willburk97 (09-07-2017, 08:01 PM), vossman77 (01-13-2018, 07:33 PM), ivnz (11-11-2017, 06:00 AM), Chris Davis (10-04-2017, 08:08 PM), Geek (02-15-2018, 07:45 AM), electricJolt (09-20-2017, 03:07 AM), TAGG (10-10-2017, 06:40 PM), Longbush Powerwall (12-04-2017, 07:27 PM), SWEwall (12-02-2017, 03:32 PM), chris.groothoff@gmail.com (12-12-2017, 12:46 PM), WildCard_25 (08-25-2017, 04:08 AM), fivestringkilla (09-12-2017, 07:38 AM), Eliot Anderson-evans (09-26-2017, 01:57 PM), Olberg (12-14-2017, 06:50 PM), mr_hypno (09-08-2017, 01:39 AM), floydR (11-10-2017, 05:46 PM), Zuluwarlord (12-03-2017, 02:10 PM), SimonW (09-07-2017, 11:54 AM), Azuria (09-15-2017, 03:40 PM), skjold petersen (09-16-2017, 04:40 PM), jrobida (09-19-2017, 04:19 AM), grgdgreek (09-08-2017, 12:43 PM), DarkRaven (11-10-2017, 06:03 PM), umop-episdn (09-07-2017, 11:34 AM), turky85 (02-13-2018, 07:59 AM), Gerard Achternaam (09-24-2017, 09:01 AM), nautal (09-07-2017, 10:16 PM), Grumplestiltskin (12-28-2017, 11:41 PM), SemaJG (12-06-2017, 05:31 PM), Thomas Koorneef (10-15-2017, 02:13 PM), Lucian Macota (09-19-2017, 05:30 PM), Joey T-Bone Smith (01-17-2018, 09:02 PM), osweld (09-18-2017, 09:25 PM), BernieS (10-21-2017, 08:14 AM), Grant Mercer (09-26-2017, 12:25 PM), Jeffrey Martin Smith (09-24-2017, 04:06 PM), ChrisD5710 (09-24-2017, 12:46 PM), jesse.rizzo (12-03-2017, 06:17 PM), James_H (10-11-2017, 10:15 PM), Darren B (01-09-2018, 09:28 PM), WallBender (09-17-2017, 03:34 AM), Kale Francis (10-22-2017, 08:09 AM), Tostaki (11-18-2017, 08:59 PM), badjaw (10-16-2017, 06:34 PM), howiegrapek (12-21-2017, 02:13 AM), cristof (11-19-2017, 05:00 PM), accoelho (10-09-2017, 12:40 PM), neurocis (12-16-2017, 04:47 AM), Bryn (11-05-2017, 11:33 PM), Dragosh Shescu (10-07-2017, 06:05 AM), Markus (10-23-2017, 12:10 AM), shonalex (11-18-2017, 08:22 PM), robertokochhann (12-27-2017, 12:40 AM), tin (10-09-2017, 07:22 AM), sirhc1619 (10-11-2017, 11:24 PM), Richard Ramos Bucatan (11-10-2017, 11:11 PM), kakajaf (10-23-2017, 10:35 PM), Leslie King (11-11-2017, 01:34 AM), Elecjim (11-19-2017, 07:30 PM), tthorner (12-15-2017, 04:51 PM), 4point0 (10-19-2017, 01:17 PM), xXxOlivierxXx (11-26-2017, 11:30 PM), silangovan14 (10-31-2017, 01:29 AM), gtimo77 (10-31-2017, 06:45 PM)
