Panasonic CGR18650CG Cell Specifications
Brand:Panasonic
Model:CGR18650CG
Capacity:2250mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1500mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
430mA Standard
4330mA Maximum
Description:Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Panasoni...8650CG.pdf
Pictures:
bfleury likes this post
Just had a strange experience with these cells.
One of my cellbanks 112p was indicated low by my Batrium, so I swapped in another cellbank.
ICharger reported 182 Ah cap, (should be 250)???
Desoldered all fuses on the positive side and found that 24 of these cells were zero volts which were the number mounted. ?? Seems that they had committed collective suicide.
What I, so far have checked of the Remaining 88 cells of various makes and models, seems to be OK.
Think I will have to inspect my other cell banks to see if any more of these cells are mounted and if they are OK.
ChrisD
It would be interesting to find out what the IR of these cells is or was.
My findings on any CGR******* Panasonic cells is anything >65mΩ  (AC Impedance, 1000 Hz 4 wire kelvin as per manufacturer) is suspect to SD and degradation.
100kwh-hunter likes this post
I had 2 of these cells trip CID in storage. Sounds like all your cells tripped CID during use.
Update data sheet
The first post link has expired
.pdf   Panasonic CGR18650CG.pdf (Size: 64.53 KB / Downloads: 2,443)
If You accidentally charge these cells in sub-zero temps, this is what they do. Last spring I had 42 cells that just stopped working.
