Panasonic NCR18650BE Cell Specifications
Brand:Panasonic
Model:NCR18650BE
Capacity:3000mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
909mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
606mA Standard
3636mA Maximum
Description:Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://keeppower.com.ua/download/2015-07/NCR18650BE.pdf
Pictures:
I've posted a couple of images in requested thread.
Btw, the capacity I've measured on brand new cells when charging to 4.2v, waiting 24 hours and then discharging at 500mA to 3v is 3326mAh, 3184mAh, 3180mAh, 3176mAh and 3165mAh.
mike likes this post
I expect nothing less from Panasonics! The spec sheet says typical capacity is 3180mAh but the official spec is 3000mAh. It's the typical "you get what you pay for", except working in your favor this time Smile
