Samsung ICR18650-22F Cell Specifications
Brand:Samsung
Model:ICR18650-22F
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
440mA Standard
4400mA Maximum
Description:Green Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.tme.eu/de/Document/71b610093f...50-22F.pdf
Pictures:
Initial internal impedance ≤ 100mΩ
Dear Friend
I removed my Toshiba laptop battery for replace due expiring of battery. But the matter is above battery difficult to findin the market now.
Pls let me know any compatible battery type by Panasonic and LG for Samsung ICR18650 22f.
These cells are commonly found in Aldi Infinty 20 V Drill Batteries - 5S2P
I have recovered 70 from new batteries and Capacity/Resistance tested them 3 times with the Lii500.
Average Capacity tested from 4.1 volts - 3 volts - 4.1 volts x 3 = 2144 Mah
Average Internal Resistance = 54 mOhms
Average final voltage = 4.12 V
These are going into a 4S16P battery for 5050 LED strings and security camera.
Hope this helps someone.
cheers
emmsee  Big Grin
