Samsung ICR18650-22FU Cell Specifications
Brand:Samsung
Model:ICR18650-22FU
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
2200mA Standard
4400mA Maximum
Description:Green Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Found these details on Alibaba.com
SAMSUNG ICR18650-22FU
Nominal Capacity - 2200mAh(0.2C,2.75V discharge)
Minimum Capacity - 2050mAh(1.0C discharge)
Charging Voltage - 4.2V±0.5V
Nominal Voltage - 3.6V
Charging Current
Standard charge - 1100mA
Rapid charge - 2200mA
Charging Time
Standard charge:3hours
Rapid charge:2.5hours
Max.Charge Current - 2200mA
Max.Discharge Current - Continue discharge at 6600mA(3C)
Discharge Cut-off Voltage - 2.75V
Weight - 44.5g max
harddinero and mike like this post
